TB new line of Coax FR drivers
Hi Freddi,
I tried putting that network in XSim, this is what I get.
Without the network:
attachment.php
With the network:
attachment.php
You're crossing at about 4khz iirc ? With a dsp and an active crossover would you start lower or are there compelling reasons to go high anyway?
Yes, I'm crossing that high because of the peaks on both the woofer and the tweeter. That's where I have the smoothest transition.
If you are going active, you will be able to take out those peaks and cross wherever you like.
I wouldn't go too low. Depending on the slopes of your XO, I feel the tweeter gets stressed under 1.5kHz, if you're asking it to supply sound to the curves at that frequency.
OK, I just wanted that tested!
With dsp-xo time alignment would be easy. I have tried these one-knee xo s but they are very tricky, I can't get good sound. I have played music and they sound OK until I switch back to regular LR and then sound clears up, but step is naturally different. My latest attempts were with SEAS MR18 coaxial, others with regular 3-ways.
Many have tried KEF Uni-Q coaxials but I don't remember a single published xo with 1st order xo. This is a nice one by member "gornir"!
I just gave it a shot for fun.
Here is the resulting XO using "gornir"'s XO, adjusted a bit for little differences between the drivers.
As you can see, the impulse is not clean, and looking at the square wave output, it's pretty garbled up.
I'm sure if I listened to that, I would feel the speakers fuzzy, not snappy, and a blurry sound.
Compared to my XO at this point and time.
The impulse is cleaned up, the square wave output much better defined, and the phase between 100Hz to 6kHz is flatter.
I still need to see if I can clean up the step response and bring the tweeter and woofer together, without adding complex networks like the one Freddi posted, if possible!
This may sound a bit too much obsession about first order filters. I know... But, there is one more thing I would try in an effort to bring the tweeter and woofer together: SERIES first order filter (in the attached pic).
In a conventional parallel filter both drivers "see some voltage" and then they do whatever they want as dictated by their impedance and phase response. In the series filter, however, you are pushing the same current through both drivers over a rather wide range of frequencies, thanks to the shallow 6 db filter. Chances that you will get a much better phase coherence. This worked very well in my FAST experiments while integrating a mid-tweet to a woofer.
If you wish to give it a try... First, I would start with a fixed, smallish inductor (like 0.15 mH) and play with a large range of caps. Remember, in this circuit, the parallel inductor protects the tweeter quite well around its resonance. You only need to make sure that the overall impedance does not drop too much when you try a largish cap. Again, I would surely try non-inverted tweeter in the fist place.
Joined 2008
Murat, did you get yourself a pair of these drivers ? (w6-2313)
Mark wants to know. Thanks !
Been on vacation for a few days.
I'll see what I can do. :)
