Aleph J illustrated build guide
Finished my ALeph J boards
Finished my Aleph J boards, now on to the PSU.
I bought a matched 2SJ74 quad from Spencer at FET Audio | Hi-End Audio Projects when he still sold them quite a while back. They matched perfectly for Idss.
I changed C1 from Wima MKP4 to a Russian military/space/atom grade Polyethylene-Terephthalate (PETP) capacitor OCK73-16B 1uF 63V +/-5%. We'll see how it sounds, and if it is an improvement. Not only does it fit well, it also looks the part with the matte golden colour.
I also used a Nichicon Muse capacitor in position C4, and increased the value of C5 from 5pF to 10pF.
I have a question about the precious 2SJ74 pair: can I put a small piece of shrink tube around them, or is it better not to heat them too much and use a small cable tie-wrap?
R101 10K
R103 100K
R102 10K
R104 100K , put 6p8 to 10p across R104
C101 22uF Elna Silmic , put 1uF solid cap as bypass
also put same bypass across C103
in schematic you show us in post #3212 , just ignore (leave unpopulated) R7 position , and suddenly you'll have proper arrangement
Thanks, so let's validate the whole stuff:
You shall see that I have left R102=100k. If I put R102=10k the gain of the amplifier explodes!
Me, I'm curious of the way it works.
I've checked the models (I'm using the IRFP244 model because it seems that the IRF244 are hard to find) and the load lines are as follows:
So it seems to me that in the "Aleph 3" both devices (upper and lower) cooperates to the output.
This way (on the simulator) I get 33.1W @ 0.018% distortion.
1.82A delivered by the "power supply". 56.5W dissipated by the mosfet (84.7W when idle).
Too good to be true, but encouraging.
Hi Astromo, would you mind telling us how much you paid for postage of the 5U Deluxe chassis to Aussie?
Cheers!
No worries - shipping came to USD$57.16
The order included:
1 x Riser Panels - 2 pieces of 150mm x 90mm
1 x Riser Panels - 2 pieces of 150mm x 180mm
1 pair of black milled aluminum handles
1 set (4 pieces) of Anti-Vibration feet
The above really didn't count for much in terms of weight / bulk but in the interests of full disclosure, there you go.
For additional info, the above was marked on the con-note as a 16'ish kg shipping weight.
Does that cover it for you?
This works!
Both XLR+ and XLR- "see" the same input impedance.
Now my last problem is that it has too much gain.
With 260mV PP on the balanced side I get 34W with 0.1% distortion.
I need to find the good configuration so that my Audiolab M-DAC+ doesn't overload it (while keeping the same input impedance "seen" by XLR+ and XLR-).
In the service manual I read for the output voltage
4.5Vrms ±0.1 (Balanced)
2.25Vrms ±0.1 (Unbalanced)
Any suggestion?
Hello member teodorom,
I think you may wish to increase the self inductance of the windings of your simulated transformer "L1 L2 L3". When they are 100 microhenries as shown in post #3237, the simulated currents that flow in the transformer are enormous! Almost ±15 amperes peak to peak, more than 10 amperes RMS at 100 Hz: wow!
I suggest you think about increasing the self inductances by a factor of 1E4 or 1E5, to make the simulated current values smaller and more realistic.
_
Thanks.
I took the input stage from the "Aleph 5" schematics.
I was able to get the appropriate values for the RCA input, but I don't understand what I need to do with the XLR input.
Please consider the resistor values as "tentative".
