Both are permalloy😕😕😕
I found: DSC 2.6.2 has E25 Permaloy:
2PCS / 10K:10K permalloy audio isolation transformer, balanced and unbalanced conversion audio isolator in 2PCS / 10K:10K permalloy audio isolation transformer, balanced and unbalanced conversion audio isolatorda Transformers su AliExpress.com | Gruppo Alibaba
Thanks.
I used some time to the read BBB. BBB are great with Botic, it's has 8 I2S and 4 DSD data, it's using clock matched to 48Khz music mource and can use the external as schematic of PPY.
But BBB can't convert PCM to DSD.
You can combind AK4118 + AK417 for Coxial/Optic Receiver and use I2C from BBB to control them?
If data are DSD => Signal send to DSD Board.
If data are PCM => Signal send to AK4137 for the Convert => DSD Board. Next/Pause/Sample Rate change...can make POP.
Direct DSD
Why bother with conversion? Wouldn’t it be simpler to pre-convert PCM to DSD with one of online available converters, and feed BBB directly from USB, SD card, or network storage. That could also include native DSD. I wonder if it would be possible to stream from wifi using Volumino or similar player.
I'm having a bit of a problem with my DSC1 setup and I'm hoping someone has been down this road before me.
My Setup: Roon -> HQPlayer -> BBB -> Ian's MCFIFO + McDUAL -> DSC.
I'm able to play 44.1 sample rate files no problem, I'm able to play 44.1 and then 48k sample rate files, again, no problem. When I try to play a 44.1k file after a 48k file I get a pop (un-muting I'm guessing) and static. After I hear static any file/sample rate I try to play all I hear is static.
Power cycling the BBB and/or DSC has no effect - Power cycling the whole box allows me to again play any sample rate with no static (and it sounds fantastic).
Any ideas?
Any ideas?
I need for convert CD Mechanical. It's have coaxial/Optic output :ngủ:Why bother with conversion? Wouldn’t it be simpler to pre-convert PCM to DSD with one of online available converters, and feed BBB directly from USB, SD card, or network storage. That could also include native DSD. I wonder if it would be possible to stream from wifi using Volumino or similar player.
Oh, I see. However my proposal/question was intended to find out if somone has done/thought of such approach, because that is how I would like to do it. Any suggestions or experiences would be helpful.
Why bother with conversion? Wouldn’t it be simpler to pre-convert PCM to DSD with one of online available converters, and feed BBB directly...
If I only listened to DSD I would consider doing as you suggest, however, I have systems, such as my home cinema setup and my headphone amp/dac that can only use PCM.
Also, although my experience of this area may be out of date, tagging of PCM files was much better than for DSD.
Finally, I would want to be sure that any pre-conversion sounded as good as the on-the-fly conversion performed by HQP.
PureDSD DSC2 stuffing guide
Stephanlj, thanks for your impressions on the LL1684s. I ordered and received a pair from K&K Audio and am looking forward to trying them out. Did you add any additional loading / snubbing to them? I saw some recommendations on this in https://www.diyaudio.com/forums/digital-line-level/254935-signalyst-dsc1-85.html#post5419165, though I'm not sure if the latest PureDSD DSC2 has footprints for them.
I'm not sure who on this thread is going to be building the PureDSD DSC2, but I have put together a guide for component placement to use when I start my build. The silkscreen is ambiguous for some of the 0603 / 0805 parts and I have attempted to document the correct places for these components. I did this by hand from the schematic and Gerbers, so be forewarned that there may currently be errors. I have attached the guide and would appreciate a second pair of eyes - and wouldn't suggest using it without it getting a second review.
Greg
Greg
Greg,
DSC2 has connections for LL1684, Pavel wrote that he did not install a snubber and that people told him that it sounds better without.
Progress on my DSC2 project has slowed down as I have some trouble-shooting to do. If I try to send music to it from HQP the networkaudiod process on the BBB stops. I'll disconnect the BBB from the Hermes/Cronus and try to get it working on its own with its internal clock and then progress from there.
Ray
Ray
For sale DSCV2.5.2 complete
For sale DSCV2.5.2 built by Pavel, unsoldered end-stage, with original Chinese transformers. It is in the orginal state as delivered by Vit. Located in Europe. I am selling due to time constraints.
Pieter, pm sent
thanks
Pepe
Where to buy the SMD sockets for the resistors array?
Can I use 22,XXX & 25,XXX clocks in place of 45,XXX & 49,XXX?
See this post Signalyst DSC1Where to buy the SMD sockets for the resistors array?
Yes.Can I use 22,XXX & 25,XXX clocks in place of 45,XXX & 49,XXX?
For BBB you must change the parameters in /boot/uEnv.txt
snd_soc_botic.clk_44k1=22579200 snd_soc_botic.clk_48k=24576000
The link shows DC conectors not SMD sockets for resistors array.
I use Amanero & I know how to convert Amanero to slave, thank you.
Did you find a error in the BOM?
I don't see:
U1, U2, U3, U4, U5, U6, U7?
Amanero needs his own PSU or is feed from DSC 2.6.2?
- Digital Line Level
- Signalyst DSC1
