Can you tell original file from tube amp record? - test
Which file is the original and which do you prefer
  • Apricot is the original file
    Votes: 7 46.7%
  • Avocado is the original file
    Votes: 5 33.3%
  • I prefer Apricot by listening
    Votes: 7 46.7%
  • I prefer Avocado by listening
    Votes: 7 46.7%
  • Total voters
    15
  • Poll closed .
Administrator
Joined 2007
That's great :) You can paste the text into the forum using the 'Code' tags and then its easily viewable.
Maybe an ABX test of sober vs nicely floating could be interesting ;)
Code:
foo_abx 2.0.5 report
foobar2000 v1.4.1
2018-11-28 10:06:07
File A: apricot.wav
SHA1: 366faaef08134ef83262c95ee8a5ccbdeedb7395
File B: avocado.wav
SHA1: b404fd5526030ace6f56bead6dd1f780cab0a533
Output:
DS : Primary Sound Driver, 16-bit
Crossfading: NO
10:06:07 : Test started.
10:10:15 : 00/01
10:11:05 : 00/02
10:12:15 : 01/03
10:13:35 : 02/04
10:17:33 : 03/05
10:19:28 : 04/06
10:21:39 : 05/07
10:23:55 : 06/08
10:25:39 : 07/09
10:26:24 : 07/10
10:27:22 : 07/11
10:27:59 : 07/12
10:28:56 : 08/13
10:30:21 : 09/14
10:31:26 : 10/15
10:33:03 : 10/16
10:33:03 : Test finished.
Total: 10/16
Probability that you were guessing: 22.7%
 -- signature --
fa2dc3771d9f1801859a45fdb5a81775fa87f01b
yep it's used equipment alright, nothing but run of the mill JBL Pro computer speakers direct from whatever the soundcard is in my computer...(shh.... that's why studio engineers have their favorite crap speakers you know those auratone thingy's ...oops scotch talking...) after 30 years of doing live sound and recording i should be deaf...and oh i have a notch centered around 2.2k in my left ear...notch i mean scotch...
Have to admit, Broskie's medicine is potent stuff, with flu or not, headphones or speakers, no can differentiate reliably. :(
Apricot is a smidgen sparkly and avocado is a bit warmer, my son prefer avocado but I can live happily with any, no preference, difference too subtle for a grampa's ears. :D
Based on my 2 latest tests (the test with the tube link stage and this one with the hybrid power amp) I have decided to install this hybrid tube-SS amplifier as my main amplifier in my audio chain, for some time, like 1-2 months and get some long term listening impressions. The distortion seems to be just at the edge of audibility, it means it does not disturb. Power stage is a class A power buffer with local linearizing feedback, which results in distortion below 0.001% when in class A. Input impedance of the power buffer is 1Mohm (good for tubes), output impedance is 0.23 ohm, which makes acceptable DF. Output power is >40W/4ohm, >20W/8ohm. Class A operation is up to 18W/8ohm and up to 9W/4ohm. My speakers impedance is >= 6ohm. I think I will be able to live with it for some time. There is nothing disturbing or annoying in sound of this amplifier.
TNT, are we understanding this the same way? 8 correct out of 15 is not better than chance, and would mean that you can't hear a difference.
Jan
Sorry for commenting that late, but although it is a common misconception it simply does not mean "that you can´t hear a difference" .
It just means that the result is compatible to the assumption that was used to analyze the test statistic (test statistic means accumulated number of correct results) and the assumption of the null hypothesis is p = 0.5 (i.e. random guessing) .
That might seem to be academic but in fact is a very important distinction.....
