Salas SSLV1.3 UltraBiB shunt regulator
Hello,
I did set everything up. LEDs were on, and I set the Voltage with a dummy load. Good to go.
When I connect the grounds of positive and negative rails, light goes off, no more than a view millivolts left.
I do have two separate windings on my transformer.
Any Idea?
Ok, it turns out, labelling of pos. neg. rail, and of 0, VDC is completely upside down.
I use plastic 3mm screws for fets and I still have problems once in awhile in getting them insulated. As Salas said, measure fets to ground. Let us know what it is.
Continuity test from MOSFET tabs to some exposed chassis point (a large part's mounting screw or something) should show. Having DC between the zero output points is a fault. The current limiters saved the regulators when he wired them common and powered them up as they went down to mV outputs and dark.
Here is my Ultra BIB power supply, working just fine from first power. Without touching the pot, each board was already at around 15.5V DC output, a few turns to get 17V was all that was needed.
Regs tested with 120R 5W loads. They take a while to settle to 17V so need to set at around 17.25 at start.
Will have a look with the picoscope later and connect to the DCG3.
YouTube
