Thanks for the words of encouragement. It certainly felt dark for awhile. On the brighter side it forces me to clean up and throw out junk or donate stuff I don’t need. Fortunately, no irreplaceable items like photos or records were lost. No one was hurt either but, man, talk about a lot of work. Luckily I have a good friend who brought his whole family over to help with the cleanup - really blessed with good friends.
The one thing that survived intact was the main electronics lab bench as it is a tiled area. Although if drywall turns out to be damaged they might have to replace bottom 12inches from the floor on all affected walls.
Right on X!!
You have some good friends here on the forum too! Just a pity that we cannot help with your current situation X.really blessed with good friends
You have some good friends here on the forum too! Just a pity that we cannot help with your current situation X.![]()
A agree with this comment!🙂
X,
Sorry to hear about the hardship. But looks like you are on track to getting it sorted out, and great to see your friends give a helping hand! Also it's a relief that nobody got hurt.
Hope you can get the affected parts of the basement fixed quickly. Keep us posted!
Thanks for the support from all my friends on this forum! You guys are what keeps me motivated to make new projects! I miss the speaker lab that’s for sure.
Hope things get settled quickly and that you can return to normal comfort. I had a basement flooding in 2000 and I know the feeling..
Do
Do
Thats a tough one, X. I have been through this with relatives. Learned a lot about putting a basement back together. Good luck.
McD
McD
It’s amazing how many people have also gone through this type of a home disaster. You would think water sensor alarms would be standard requirement (like a smoke detector). I just bought 8 of them and will place them wherever a leak can happen (under each sink, washer, dishwasher, water heater, and of course sump pump).
Thanks for all the moral support!
Sorry to hear of your misfortune X.
On a lighter note I checked the rail voltage on my Alpha 20.
I get 23.5 v using 18v 350va transformer per channel .
Steve.
Steve.
So sorry to hear of your problem X , hope you get back to normal soon.
Your help, encouragement and support has been appreciated by so many on the Forum. All the best
Alan
Alan
sorry to hear x, that's tough luck. hope you get your workshop up and running soon.
regards
Prasi
regards
Prasi
Thanks for the support guys. The cleanup and drying has been completed. Now moving on to renovation by installing carpet and drywall that was removed. I am also going through personal effects that were wet to see if damaged. But the lab is going to be at least 2-3 weeks before back to normal.
I know there has been some discussion about filtering power for the Alpha cooling fans. Perhaps the usual strategies are already plenty effective, but I just came across this purpose-made module and thought I'd share it.
I am using one of JPS64’s CLC filters from the Aksa Lender Preamp. I have a 1000uF // 1mH ferrite core // 1000uF cap with 51R in parallel across the inductor. It stopped the fan noise dead. If you look at JPS64’s layout for Alpha BB you will notice a built in CLC in the main board for the fan controller power supply.
Thanks for the link to that fancy CLC filter though. It looks like some nice components used genre.
Recently I have had a few people contact me that they were preparing to start a new build on a 4ohm Alpha 20. Here is a schematic with the changes needed for a 4ohm speaker Alpha 20. Thanks to Pinocchio for adapting the schematic with new values for 4R operation.
Which reminds me, did you ever finish your build of the Alpha, Pinocchio?
Yes, yes! Awesome, thanks for posting that, and perhaps a link on the 1st page of your thread(s).
Pinocchio rocks!
Best,
Anand.
- Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
