Another one in the wild. Bias set to 112mA. 2SK2013/2SJ313 output devices. LM4562. Sounds awesome, thanks Wayne!
Where did you pick up your volume control?
eBay. Search for dact type smd attenuator.
@funch,
I had this from meldano => http://www.diyaudio.com/forums/swap-meet/322983-muses-volume.html#post5440394
Great builds here and lot of knowledge. I see some of you are using Audio grade capacitors for C1 and C5. Is this a good alternative to C1 and C5 capacitors?
Mundorf 1mfd EVO Oil Capacitor
I use this cap. Not sure if there is any benefits for the sound quality.
I have some extra money to spend and it looks beautiful to me. So I put them in my build.
will there be a big difference if he will fit lm317 and lm337 instead of 7915 and 7815 because they are better?
LM317/337 have a different pinout and will not fit.
I use Mundorf Supreme capacitor and they sound lovely. Took me a bit time to fit them nicely
Here is my first Pass amp, learned a lot here. I've tried a few OPAs and finally settled with AD823 so far, will try OPA627 X 2 soon, this amp sounds amazing
Ok but adapting to an external card is not improving compared to the simple 7815 and 7915?
Considering how low the ripple is from the passive filtering, it's doubtful the 317/337 would be much improvement.
However, It would be interesting to know for sure and very easy to implement. Give it a try!
Ok, thank you I have several pcb I will try on 1, I will keep you informed ....
- "WHAMMY" Pass DIY headphone amp guide
