it could be posible to reduce the one side and increase the other?
Usually that is not a problem.
dave
ok if for exemple i want to use a depth like 70mm i can cange the other parameter for have the same liter size?
and then how i can manage the dimension of the shape and the place of the vent port?
Which design are you looking at?
dave
for example if we take the lite model the interior size is 121 *223 *100mm plus the vent port
for example could i use the mesurament like 70 *223 *172mm that is the same volume?
and the event port how i will setup it?
thanks for the answer
70 *223 *172mm
2.68 litre
40 * 200 * 337mm
2.7 litre
As designed volume is 2.7 litre so either of these would work. You would need to put the vent on the top or bottom so as not to obscure its entrance. The shape is a triangle but any shape could be used as long as cross-section and area are maintained — only the skinnier box would require that thou.
dave
Ok
I will go with this volume
40 200 337
Now I will put the vent port on the bottom
What it could be the dimension of the port?
Like 10mm 200mm for?
And the ap it will be put where ever we want? Or have to be in the center?
Or maybe I can use the same place of the original project from the top?
40 200 337
Inside dimensions. You could get away with 9mm quality ply (oe 3mm aluminum) to shrink things as small as possible.
Current vent is a 4.5 cm right triangle. Cross section is 10.25 cm)sup]2[/sup]
Like 5mm x 200 mm.
Distance from the closed end of the box is fixed, side-to-side you can put it wherever you want (but not too close to a sidewall).\
dave
Joined 2009
I'm getting old. I see that I've posted the same thing recently as I did about 5 years ago ! Talk about droning on with the same old stories 😀
Like 5mm x 200 mm.
dave
5mm x 200mm x i miss the last misurment what it could be lenght?
thanks
If I want to put inside at a close box what it could be the right lilters?
I read that 1,3L it is Ok you could know if is ok for the fe85?
Thanks so much
Thanks so much
dave
this distance is 127mm like hybrid or 57mm ken lite ?
can i use the 57?
i like to have the ap near the top.
thanks fo r the answer
- Full Range
- The Fountek Five for FR88ex
