Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
The BB build has started......
Hi JP,
Very nice universal design.
Do you have an alternative heatsink to use for the rectifier board? If it’s the same heatsink as your F6 psu design, I don’t think we can’t source it in the USA.
Vunce
netweight 429g
GAMMAXX 300 DEEPCOOL- CPU Air Coolers
Fan Speed 900±150~1600±10%RPM
Max. Air Flow 55.50CFM
Noise 17.8~21dB(A)
Reported on B.B Alufins 28C VS heatpipe 38C on 10%Rpm
Deepcool S40
Net Weight 610g
specs 17.8~26.1dB(A)
noisy compered to the almighty deepcool 300
Net Weight more on 181g on deepcool s40
DEEPCOOL GAMMAX S40 CPU Cooler Review
temp over ambient temp 24.5-25°C
Mpemba effect?
Maxwell demons?
atmosphere pressure?
Ranque-Hilsch vortex tube?😕
Tonza,
Thanks for the cpu cooler links. I missed the fantastic price on the
Gammaxx 300 so I went for the S40 since it had four 6mm diameter pipes and the same price as the 300.
JPS64,
For some strange reason even the Aavid Thermalloy - os520-100-b is not obtainable in the USA? Maybe my search skills are diminishing 🙂
That’s really weird 🙁
Can I use a 0-22v 6.8A x2 (dual secondary) toroidal for the Alpha 20W board? Is the voltage more and if its the case can I use a higher wattage and low resistor on the CRC psu board to achieve the required voltage. I have this in spare which I can use and if not this I need to use my other spare 0-18v 7A x2.
