Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
SEF
this one goes in prototype
probably it will not oscillate , but gate stopper is conditio sine qua non , at least in my head
so , no need to draw it all the time , especially when I forget ..... :rofl:
(so , that was good question!)
rationale for output resistors arrangement is nothing else than THD spectra ( and dynamic behavior of mosfets in output)
it looks best this way
edit: just checked - both gate resistors are included on pcb 🙂
btw ....... made sanity (sim) check of 2SK180 based DEFiSIT , made with ACS chips
nada - not big enough (voltage) window between gates of 2SK180 and IRFP9xxx to keep current in sane bracket
same case with SJDP
Sorry to quote a relatively old post, but the "1, 2, SIT3" thread triggered me to ask again.
I have some 2SK180D, that gives Id of around 1.5A at Vgs of -3.2V (Vds=20V), would they be feasible devices for the DEFiSIT. (attached are the measurements of the 2SK180D).
Thanks Mr. Pass and ZM 🙂 . It seems quite possible to find a matching P FET, but I'll need to get familiar with the SPICE circuit first.
I have another question though, if you don't mind. In the "DEF Amp" thread, it describes a way to adjust the Vgs matching through 3 resistors. In the DEFiSIT amp, opto-coupler is used - what is the reason for the change.
