Thanks,
would this ones fit ?
CBP 2: Cinch-Einbaubuchse, Farbcodierung rot - weiss, vergoldet bei reichelt elektronik
Ronny
Ronny
No, they are a bit wider and pins are not at the same place...
These are more likely to fit:
8pcs Right Angle Panel Mout PCB RCA Chassis Audio Jack,QG-in Connectors from Home Improvement on Aliexpress.com | Alibaba Group
They might require drilling a ground pin hole though.
This one is now for sale, assembled it only to test new boards. I also have fully assembled PS, 220V voltage only.
Hi, how much is ist?
Ernst
Ernst
Fully assembled kit with PS, rotary encoder, IR sensor + OLED: 200eur , with LCD: 180eur.
Hi, I'll send you a PM. Best, ErnstFully assembled kit with PS, rotary encoder, IR sensor + OLED: 200eur , with LCD: 180eur.
A small bug was corrected in OLED code - volume bar was missing after exiting setup menu.
VxD - Google Drive
VxD - Google Drive
My LDR based DCG3 preamp build is coming along nicely. Excellent LDR kit with psu and OLED provided by zdr.
which oled do you use?
Oled provided by zdr in the kit, so I guess he could tell you the source. Its a really nice and easy readable display. 🙂
I will put up an updated code for OLED which has a screensaver. I did not have any burn in issues so far, but OLED tech should be susceptible to that. Better safe than sorry.
This is the link to OLED I used:
I2C 2.42 128x64 Graphic OLED White Module ( Arduino / PIC / Multi-wii) with Hole | eBay
Thanks, got one in yellow, he has colors he does'nt show if you write him.This is the link to OLED I used:
The LDR's I found at an ok price here, that is if they're the right ones🙂
LDRs are also available here at a resonable price.Thanks, got one in yellow, he has colors he does'nt show if you write him.
Silonex NSL32-SR2 :: Optocouplers :: Optoelectronics :: Electronic Parts :: Banzai Music GmbH
Silonex NSL32SR3 :: Optocouplers :: Optoelectronics :: Electronic Parts :: Banzai Music GmbH
I've bought 5 of the PHOTONIX LDR's, just to be on the safe side.
Is there a simple way in which I can identify the "odd one" with reasonable certainty? I believe I've read something about a LDR-tester, but is it possible without? Thanks
I'll bite - what's the odd one?🙂I've bought 5 of the PHOTONIX LDR's, just to be on the safe side.
- Analog Line Level
- Arduino based LDR volume and source selection controller
