It can supposedly handle 200 watts...I could not pass 50 watts how loud it was, yet unbelievably clean
Thank you. I had forgotten about that thread. I even posted there! 😱
Not much info about how the 8FE200 sounds vs other midranges. I take from the above posts the 6FE200 sounds very detailed and undistorted compared to other very good midranges, be them pro or "specialty" hi-end. Those are the traits I'm looking for, plus hi-sensitivity, for 350-2000Hz. They seem to be very good candidates to pair in MTM with a TPL-150H.
I just came from Buenos Aires. Well, i only spent two and a half day there, primary destination Patagonia.
Well, i was thinking about paring 6fe200 with beyma...well, the price. I am building speakers for fun, and frankly run out of rooms, have too many speakers already...since i had prior great experience with Hivi planars, that's what i am using.
Only depends on how much you are willing to spend !
FaitalPRO | LF Loudspeakers | 8PR155
Interesting! Fly fishing perhaps? 😉
I'll be heading for the Patagonia Andes in two weeks like I've been doing for the last 8 years. Can't wait! Hope you had a good time.
Once back from Patagonia I plan to try MTM with Faitals I have around (M5N12) and see how it behaves lobing-wise. Going MTWW with 8" midrange is an option, or MTMWW with these 6". Need to try out and decide.
Indeed, these are good 8" candidates, together with B&C 8PE21...and a W7-1772 😱
That's how i use it in three systems...
Interesting! any detail?
Question for Adason: why did you decide between the 6FE100 and 6FE200? The frequency chart looks similar.
I used the 5FE120 in a project and was very pleased with the mid-range. I had an MTM with the Dayton PT2C-8 as the tweeter.
6fe200 has no nasty peak at 4kHz, and can go without inductor up to 5kHz, no nasty breakups, plus its 95 dB/watt/m, while 6fe100 is 91...otherwise nothing against it
I used 5fe120 with Neo3 in another project...ok sounding, ordinary efficiency
no, not really, its right now sitting on top of 15" closed box woofer, active B1 crossover at ~160Hz (used to be minidsp), biamp with chip amps, no passive parts except one cap for tweeter, nothing for mid! May put L-pad on tweeter, but it sounds great right now.
So all in all, one cap...!
Thanks. Now I want to try it! (damn it.... just what I need; another project)
it's a good thing! 🙂
here is how it looks
recently finished...
- 6FE200 + ST200
