Aleph J looks great and sounds even better.
Beauty is in the eye (and ear) of the beer holder.
Beer holder . Very good, I will use that. The heatsinks are running comfortably warm. I am running 20 volts on the rails so heat dissipation is not an issue yet. I do plan on replacing the power transformer with an Antek AN-5218 500VA dual 18 volt. I might need to improved flow. The amp sounds really good, I might just leave it alone. You will see I went external on the speaker relays. I could not bring my self to running the speaker wire from the right amp board to the left side and back again to the right speaker binding posts. I also put the speaker hot lead on the common lead of the relay and the N.C. lead to ground, along with the N.O. going to the Red speaker post. In the event of a failure the relay should take the hit not the speaker. The speaker protector board makes the Alph J totally thump-less.
F5 Mono Block, a bit over the top.
Never seen anything like that before
A tube-like build style for a solid-state amp. Full votes for artistic impression!
It rang a bell :
http://www.quadesl.com/pdf/hpart.pdf
Patrick
It rang a bell :
Patrick
Pass DIY Addict
Joined 2000
Those F5 monos made me think of Mark Finnis' tube-style a40 amp from a loooooong time ago. Mark helped me build my a40 about 16 years ago - this was my first DIY amp and it still sounds great! Nor sure if Mark is still active around here or not...
The beauty of this construction method is you can replace the top piece of sheet metal , making changes easy. You can place components above and below the chassis thereby keeping wires short .
Nice one.
Is that a toilet paper roll (testing a brown note) ?Under side of my F5 Mono blocks
Great job anyway !
Great job anyway !
Gee, thanks. I'd never heard of a "brown note" and I wish I never had...
- Pictures of your diy Pass amplifier
