Pearl Two
I know it would be a pain to take pic of this implementation, do you perhaps already have a pick of this setup? Do you happen to remember what switching device you used?
Getting ready to use some lower output MC, this would be super handy...
Russellc
Part is here: A10303RNZQ C&K Components | Mouser
Wiring is like the drawing attached.:)
Joined 2003
You need to be able to turn the rotary switch.
Hate to drill a hole through my face plate, I guess I could have it exit the rear panel. If it isnt too large, I can conceal it inside. I will not need to change carts very often, so no big deal for me to make "internal" adjustment. Maybe even a small board inside with Tiny DIP type switches...
Russellc
If you have room, add extra phono sockets to the back panel and wire in paralell to the input sockets, solder 'loading' resistor(s) inside a phono plug(s) and insert .....
Thats also a very good methtod. :)
Its similar to what I have on the back of my Thorens TD126 Mk III Centenial, where the ekstra plugs original was ment to be used for capacitors for MM-pickups.
Resistors? Is 0.25W mandatory?
Hi
I am a litle confused as the description of the parts needed says all resistors are 0.25W - but Wayne also writes that he mostly uses Vishay-Dale RN55D - which I think are only 0.125W :confused:
I think I could use Vishay-Dale RN60D? What are your oppinions in selecting restistors?
And by the way - why are the CMF-series more expensive than the RN series ? I would have imagined it would be the other way round (RN being military grade)?
The nice guy I bought the project from is talking warmly of Welwyn (but they are rather expensive)...
As always all your kind input is welcome :)
6L6
Moderator
Joined 2010
The RN series are derated for the military spec. The 1/4w resistors in the RN series are actually 1/2w devices. In your example the RN55 say 1/8w on the datasheet but are functionally identical to the CMF55 1/4w
The RN are also not lead-free (because the mil-spec understands the disaster that is lead-free solder and components) and being leaded, are difficult to sell.
Thanks for making this clear :up: :)
The RN55's will be allright then.
:D
