I have used an LED and a 1k resistor for R15 on the PCB thinking that it was just a power indicator. Looks like it is in the bias circuit. Looks like I need to eliminate them out of the circuit.
I believe the LED was provisioned by Grimberg for additional bias requirements.
Absolutely not! The LED + resistor go from V+ to GND, THAT"S IT!
Stand corrected. I have used LED for the right purpose then. Will post the readings in a day or so as I am traveling.
The pins/footprint for Q6/Q7 (LM385-1) regulators and JFETS are close/tight to each other. Make sure that there are no shorted solder connections. Also, there are only few resistors/components so double check values absolute correct (SOP to measure before inserting component).
Help on M2 build
Here are the readings:
Left Channel:
Minimal offset with trimpot adjusted +2.78V
P channel Source resistor voltage .. 0.667V
N Channel Source resistor voltage .. 0.673V
Right Channel:
Minimal offset with trimpot adjusted +4.09V
P channel Source resistor voltage .. 0.688V
N Channel Source resistor voltage .. 0.690V
As mentioned earlier I have used random set of Toshiba 2Sj201/2SK1530 pair (vgs of which I have never measured) and these were removed from my working F5 amp. May be there is a huge variance on the output transistors.
I do have very well matched IRF pairs and also a Fairchild Pair with a 1 volt VGS difference between N and P parts. I can replace the outputs if that is the reason for this huge offset voltage.
Thanks in advance.
Anil
please post actual schematic and pictures of build
write down what is voltage across source resistors , what is exact (minimal) DC offset you can get with trimpot on end , taking care of proper polarity (probes)
then we can help with more specific steps
Left Channel:
Right Channel:
Thanks in advance.
Anil
Left Channel:
Right Channel:
Thanks in advance.
Anil
Replaced the Toshibas with Fairchild output devices withknown vgs. Also recleaned the close spaces on the jfets and lm385s transistors. Some or all of it worked. Nicely adjusts now to under 10mv. Thanks for the advice. Now to test the amp with my Altec horns!
Cheers
Anil
I might try the Toshibas again at a later date.
You won't want to miss that
Finally played my M2. Zero startup thump or switch off thump. Cannot make out that amp is on with ears close to speakers. When fed with music, the amp comes alive with full dynamics. Terrific dynamic range and clarity. Cannot make out which of Pa’s amps are great, because all of them are. My ears have got numbed listening to some great amps from Papa. Cannot out make out which is better.
Great addition to my Pa’s amp collection. Next is VFET 2.
Thanks to Pa and this forum for giving me years of Joy. May the tribe grow!
Merry Christmas and a great new year!
Cheers
Anil
Cheers
Anil
+1 for Toshiba 2SK1530 / 2SJ201 !
(... with 0R33 for the source resistors and 0R0 (jumper) instead of 221 ohms for R11, as per suggestions of ZenMod somewhere in this thread; runs at 1.81 amps)
Best regards,
Claas
Best regards,
Claas
Will do. First want to enjoy the music for some time before attempting the Toshibas.
... First want to enjoy the music for some time before attempting the Toshibas.
- Official M2 schematic
