Bob Cordell's Power amplifier book
Here is simulation to show input distortion with input resistor of 0.1R and 1k.
Used Cordell's models.
Do I do something wrong here?
Damir
Added input distortion of my CFA.
Hi Damir,
this is indeed surprising. Always thought that balanced impedances at non-inverting and inverting inputs give best results.
But I'm wondering about the DC balance in your circuits. The inverting input sees about 20k (DC), while the non-inverting input sees 0.1||20K or 1k||20K. What does happen, if you balance the DC pathes?
Kind regards,
Matthias
Damir, there is nothing wrong. Cascode may reduce Miller capacitance but the base current is still there. CFA has partial compensation of base currents.
Dimitri, I was wondering why Cordell can't confirm D. Self input distortion not why there is one even if cascode was used in the bjt LTP.
What surprised me more is input distortion with the fet cascoded LTP I mentioned some posts back.
Hi Damir,
Kind regards,
Matthias
Matthias there is DC balance, 1k resistor is in series with capacitor.
It depends on how you cascoded it
Attached my TT amp with the fet bootstrap cascoded LTP.
Input distortion is dominate distortion in this case(0.000329%), THD20 is below 1.5 ppm with low source output resistor.
In my understanding, base current of inverting input flows via 20K, while base current of non-inverting input flows via 0.1R||20k or 1k||20k in the second circuit. So I would expect some effective offset voltage, depending on bias currents.
Matthias
OK I got it. Normally there is serial capacitor in the input here removed to simplifies the FFT. If you want DC connected input you would need DC servo.
This unbalance does not influence input distortion.
Hi Damir,
just made a quick experiment with my nested MC amp, BJT-input version from post #80 in the thread there.
I have always used balanced impedances for feedback network and network towards input source. If I now replace the input network with a lower-impedance one, then input distortion becomes worse. This is also true, if I just place lower-impedance R+C combinations across the original resistors, such that all DC conditions remain the same.
So your results really surprise me.
Kind regards,
Matthias
Matthias what surprise you?
I always thought that balanced impedances are good for distortion performance of the differential pair, since then the nonlinearities in both halves have the same influence, if transistors are identical as in simulation.
Furthermore, this is confirmed by simulation experiment with my own amp.
Your result suggests that it is better to have a very low impedance on one side. I'm surprised because I do not understand the difference between your and my experiment.
Matthias
I cannot give a reference where this believe in impedance symmetry stems from. Maybe, it was my own idea without ever really questioning it. Until now, it worked well. But if your results are true, then I have one more place to improve my design. It will never be built ... ;-)
Damir, can you explain or provide a pointer to a post describing: How does one separate these both contributions in a simulation experiment, distortion due to unbalanced impedances and distortion due to nonlinear voltage-drop across a resistor at the non-inverting input?
Thanks,
Matthias
Bear in mind that the circuit I simulated was quite close to the one that Self was referring to in his book where he discussed the input current distortion. If you simulate a "better" circuit whose base distortion at 1kHz or 20kHz with a low-impedance input, and get significantly lower base distortion, then you may see increased distortion due to the inclusion of a 1k source resistance.
All I am saying is that I was unable to duplicate his results with a circuit that was very similar to his.
Bob
If you simulate a "better" circuit whose base distortion at 1kHz or 20kHz with a low-impedance input, and get significantly lower base distortion, then ...
The baseline seems to be the problem, at least can I confirm that for the "think model" of impedance symmetry between the inputs.
In the simple conceptual model below (ULGF around 600kHz, V4 ensures small sim step), one gets lower THD, if R2 and R8 at non-inverting input are scaled down. I have also checked that e.g. collector voltages of Q1 and Q2 remain in balance after that change.
In my amp with much less distortion, this does not hold. Best performance is achieved with balanced impedances.
Sorry for the noise and any trouble, Damir.
Matthias
Older transistors that were used for the LTP in the past had worse Hfe and/or worse Vaf as well as worse Cob. All these contribute to static input distortion. The BC550C is really an excellent transistor compared to some of the others that have been used.
Just throwing that in there, it probably doesn't account for the majority of distortion in any of the examples here.
