Most Greedy Boy, of them all... or (there is no) DEFiSIT of Papa's Koans
interesting to mention - while both DEFiSIT and SEF amps are showing wakoo behavior , regarding currents through outputs - "normal" mosfet is working against both other output and load (other output subtracting current , up to clipping level , where it starts adding) .......... LuDEF amp is functioning in more common way - upper and lower output are working together , where their two smaller currents are summing in greatest current through load
now for that ......... I wish I was a fly on the wall , through time when Papa stumbled on DEFiSIT idea ..... luckily flies being creatures laughing silently
:clown:
I learn a bit by plugging different load values (2, 4, 6, 16, 32, 600 ohms) and various p channels including 9140, single and double die laterals. Warning, hold your laughter down to avoid serious stomach cramp, some combinations exhibit really nice crap.:wave:
Previous experience with Sziklai output pairs showed that it is easy to get either a real nice, stable and super low distortion output stage or a real nice, stable and super low distortion oscillator. Something somebody somewhere relate to something usually consumed as dessert.😀
It appears you have discovered the reason why Schade feedback is not
so popular for followers...
Going back to your schematic of post #193, we see that positive voltage at
the output increases the voltage across R6, driving the P channel output
Mosfet harder, so that it acts contrary to the work the N channel is trying
to perform, even without a load.
For this to work, the Schade feedback needs to be seen equally by both
Gates, an exercise I leave to your imagination.
:xmastree:
it is for some nice and lazy discussion - is it feedback , or "just" altering transfer characteristic of part itself ..... I mean - all the way from original papers of Herr Schade
anyway - I'm not loosing my sleep over anything more, regarding behavior of circuit - any possible tweaking reserved strictly to bench with real parts
what I'm finding most important is that I stumbled on exactly same behavior of output devices as you have with DEFiSIT
:clown:
to repeat :
Same for Papa's Wakoo DEFiSIT , only this time smaller voltage swing possible , 16Vpp input signal;
red - current through 8R load
green - current through mosfet (IRFP9140)
blue - current through PapaSit
edit : easy to confirm on one-rail PSU - current modulation of PSU is greater than current ending through load
652778d1514115479-greedy-boy-defisit-papas-koans-defisit-currents-16vpp-8r-jpg
Assuming no Schade resistors in circuit, it looks like Mosfet has about 3 times
the transconductance of the SIT. SIT is roughly 1 S, so P channel Mosfet
is maybe 3 S.
Maybe you put some Schade resistance on SIT and see what happens.....
Or not.....
Dunno Pa , just trying to translate what sim is showing 🙂
I'm pretty happy with DEFiSIT sound :devily: and I'm not so sure when I will have opportunity to steal it from living room (and measure some) - right now whoomping and roaring LOTR 3 Extended
:rofl:
edit : worth mentioning
- LuDEF amp is not showing that behavior , it's behaving .........
-SJDP DEF iteration is behaving
-last iteration or 2SK180 DEFiSIT is defisitly misbehaving
-Real McKay DEFiSIT is defisitly etalon of misbehaving
tried that sim and - as expected ........ in case of Part which is having already Schade effect intrinsically (Pass SIT-1) , if we connect same net as done to mosfet (10k-ish D to G and 1k-ish series to gate) , effect is Anti-Schade - increasing xconductance of part
so , further "Schade-ing" of triode-like part is possible through already known and boring methods - degeneration and cascode modulation
:devilr:
damn , I'm again doing all the work here ........... when I'm going to see my Glory Days ?
:rofl:
tnx to imdra , we came to (it seems) glorious idea of Iq sensing , with handy Hall effect IC
it is ACS723 family of chips
last few nights I was playing with sims and came to few conclusions :
-Babelfishing XA25 - swell , can't talk ;
-M2 iteration , called by Mighty Moi M25 :rofl: .... :
-8Vpp/8R - better THD than M2
-38Vpp/8R - even more better than M2
-40Vpp/8R - wakoo more better than M2
-in heavier loads ( 4R, 2R) difference even greater in favor of M25
.......... now , none of Poor Greedy Boy DEFiSIT substitutions* is not having any benefit of using Hall IC, simply because I needed source resistor in best position , as tool of shaping THD spectra ..... so nothing easier than to implement direct optocoupler biasing scheme
*means LuDEF amp, SEF amp ; now I realized that I didn't check thoroughly SJDP DEF amp and 2SK180 DEFiSIT
will do that later .....
yup
though ..... I meant to ask indra - did he found some bigger cased buggers , with same characteristics ......... 🙂
preparing one short list of special parts , to order ...... none of them being in regular stock of my usual vendors
as soon I finish that list , with ACS buggers too , I can start count 2 or 3 weeks to delivery
no 2SK180 DEF , no SJDP DEF, with ACS chips
btw ....... made sanity (sim) check of 2SK180 based DEFiSIT , made with ACS chips
nada - not big enough (voltage) window between gates of 2SK180 and IRFP9xxx to keep current in sane bracket
same case with SJDP
so , conclusion - in this very moment , ACS chips are extremely interesting for wakoo XA25 approach - pair of mosfets sans source resistors , be it oldies or pucks
I really hope reality will follow simulation 🙂
