Class D Amp with LM566, LM393 and 2XIRF530
Replace IRF640 with TIP31C in bias voltage regulator...
The bias regulator transistor is tip41c
I adjust the vr1 to 1R and problem solved but still sound is not clear hifi
The outpot filter is from an old digimod 1000 power module and i think it most be around 30uh
Hi mr mile
I build d200.2 and its sounds good but not clear
Mosfet on vs - side get warm
I used irfb 4227 and power supply is 42v ac on transformer
with irfb4227 use 250khz frequency set it with pot 1kohm. gate resistor is 6.8 ohm ----10 ohm. you must never use diode for discharging gate remouve it. ir2110 can't discharge irfb4227 with diode the limit is 2a. after regulator 12v put a 10 ohm resistor to limit peak current. put a 15v zener at high rail gate mosfet. enjoy😉
Are these mods for Apex D200?
Can you post a modified schematic diagram?🙂
i don't have schematic now. this modification is for all class d with ir2110. the problem for irs900 is power supply 12v at cd4069. 99% uir2110 is a copy or fake. with fake ir2110 mosfet get warm 2side or one side or explode or not work.with copy 90% of ir2110 it work great but with more consumption at high in and low in than original part. with 5v it's stable but with 12v not like irs900 1500
If it's a fake parts problem then it doesn't matter the class D
