Moode Audio Player for Raspberry Pi
Hi Tim,
Many thanks for your efforts with this
Beta 10 up and running, a clean install from an earlier Beta 8. As with two others I haven't found a way of getting the cover art to display. Does it now need to be a certain size, or is it linked to Chrome fore use with a monitor or display?
The build went smoothly enough, although gmusicapi seemed to hang for a long time at the final bit.
Basically everything is switched to off, as trying to keep it simple at the moment with Allo digione providing spdif output to dac, the audio is fine, just the images haven't caught up yet.
Data from system file.
S Y S T E M P A R A M E T E R S
Date and time = 2017-11-29 21:33:59
System uptime = up 33 minutes
Timezone = Europe/London
moOde = Release 4 BETA10
Host name = raspberrypi
ETH0 IP = 192.168.0.5
ETH0 MAC = b8:27:eb:a1:b0:6b
WLAN0 IP = unassigned
WLAN0 MAC = no adapter
HDWR REV = Pi-3B 1GB v1.2
SoC = BCM2835
CORES = 4
ARCH = armv7l
KERNEL = 4.9.65-v7+
KTIMER FREQ = 100 Hz
USB BOOT = enabled
Warranty = OK
ROOT size = 15G
ROOT used = 16%
ROOT avail = 12G
FS expand = expanded
MEM free = 454 MB
MEM used = 59 MB
Temperature = 52.1°C
CPU GOV = performance
MPD SCHDPOL = TS
P3-WIFI = Off
P3-BT = Off
HDMI = on
ETH0 CHECK = On
MAX USB CUR = Off
UAC2 FIX = Off
SSH server = Off
LED0 = on
LED1 = on
C O R E S E R V E R S
PHP-FPM = 7.0.19
NGINX = 1.10.3
SQLite = 3.16.2
Bluetooth = 5.43
C P U L O A D
CPU %usr %sys %idle
all 0.25 0.38 99.37
0 0.00 0.00 100.00
1 0.00 0.00 100.00
2 0.00 0.00 100.00
3 1.00 1.49 97.51
P R O C E S S L O A D
PRI RTPRIO COMMAND %MEM PSR %CPU
19 - sysinfo.sh 0.2 2 1.3
29 - mpd 3.1 2 1.1
19 - sudo 0.3 1 0.3
19 - worker.php 1.1 3 0.2
19 - cifsd 0.0 0 0.2
19 - systemd 0.6 0 0.1
19 - kthreadd 0.0 2 0.0
19 - ksoftirqd/0 0.0 0 0.0
19 - kworker/0:0 0.0 0 0.0
C L O C K F R E Q U E N C I E S
arm = 1200 MHz pwm = 0 MHz
core = 400 MHz emmc = 249 MHz
h264 = 300 MHz pixel = 25 MHz
isp = 300 MHz vec = 126 MHz
v3d = 300 MHz hdmi = 163 MHz
uart = 48 MHz dpi = 0 MHz
SD card = 50 MHz
S Y S T E M V O L T A G E S
core = 1.3438V
sdram controller = 1.2000V
sdram I/O = 1.2000V
sdram chip = 1.2250V
U I C U S T O M I Z A T I O N S
Theme color = Emerald
Playback history = No
Extra metadata = Yes
Library = Use Artist
A U D I O P A R A M E T E R S
Audio device = Allo DigiOne
Interface = I2S
Hdwr volume = None
Mixer name = Digital
Output stream = S16_LE / 44100
ALSA version = 1.1.3-5+rpi3
SoX version = 0.1.2-2
Volume knob = 46
Volume mute = Off
Volume limit = 100
Bluetooth controller = Off
Airplay receiver = Off
Squeezelite = Off
UPnP renderer = Off
DLNA server = On
Rotary encoder = Off
Encoder params = 100 2 3 4 5
Crossfeed = Off
Parametric EQ = Off
Graphic EQ = Off
Auto-shuffle = Off
Autoplay = Off
MPD crossfade = Off
M P D S E T T I N G S
Version = 0.20.11
Volume control = software
ALSA device = hw:0
SoX resampling = disabled
SoX quality = very high
SoX multithreading = off
Audio buffer (kb) = 4096
Buffer before play = 10%
Output buffer size (kb) = 81920
Volume normalization = no
DSD over PCM (DoP) = no
Replay gain = off
A I R P L A Y S E T T I N G S
Version = 3.1.4
Friendly name = Moode Airplay
Metadata display = Off
ALSA device = hw:0
Volume mixer = auto
Resume MPD after = No
Output bit depth = S16
Output sample rate = 44100
Session interruption = no
Session timeout (ms) = 120
Audio buffer (secs) = 0.0
S Q U E E Z E L I T E S E T T I N G S
Version = 1.8.7-1020 "DSD/SRC disabled"
ALSA device = hw:0
ALSA params = 80:4::1
Output buffers = 40000:100000
Task priority = 45
Codec list = flac,pcm,mp3,ogg,aac,alac,dsd
Other options = -W -D 500 -R E
M O O D E L O G
20171129 210052 worker: - Start
20171129 210052 worker: Successfully daemonized
20171129 210052 worker: - Init
20171129 210052 worker: Session loaded
20171129 210052 worker: Debug logging (off)
20171129 210053 worker: Host (moode)
20171129 210053 worker: Hdwr (Pi-3B 1GB v1.2)
20171129 210053 worker: Arch (armv7l)
20171129 210053 worker: Kver (4.9.65-v7+)
20171129 210053 worker: Ktyp (Standard)
20171129 210053 worker: Gov (performance)
20171129 210053 worker: Rel (Moode 4 BETA10)
20171129 210053 worker: Upd (None)
20171129 210053 worker: MPD (0.20.11)
20171129 210053 worker: USB boot enabled
20171129 210053 worker: File system expanded
20171129 210053 worker: HDMI port on
20171129 210053 worker: File check ok
20171129 210053 worker: - Network
20171129 210053 worker: eth0 exists
20171129 210053 worker: eth0 (192.168.0.5)
20171129 210054 worker: wlan0 does not exist
20171129 210054 worker: - Audio
20171129 210054 worker: ALSA outputs unmuted
20171129 210054 worker: Audio out (I2S audio device)
20171129 210054 worker: Audio dev (Allo DigiOne)
20171129 210054 worker: ALSA mixer name (Digital)
20171129 210054 worker: MPD volume control (software)
20171129 210054 worker: Hdwr volume controller not detected
20171129 210054 worker: - Services
20171129 210056 worker: MPD started
20171129 210056 worker: MPD scheduler policy (time-share)
20171129 210056 worker: MPD output 1 ALSA default (on)
20171129 210056 worker: MPD output 2 ALSA crossfeed (off)
20171129 210056 worker: MPD output 3 ALSA parametric eq (off)
20171129 210056 worker: MPD output 4 ALSA graphic eq (off)
20171129 210056 worker: MPD crossfade (off)
20171129 210056 worker: - Last
20171129 210056 worker: USB sources (none attached)
20171129 210056 worker: NAS sources (mountall initiated)
20171129 210057 worker: Volume level (0) restored
20171129 210057 worker: Watchdog started
20171129 210057 worker: Ready
20171129 211032 worker: Job minidlna
moOde 4.0 BETA 10 is available 🙂 This Beta contains two new features listed below. The Local UI feature requires installing Component 8 from Build Recipe 2.0.
- Local UI display
- Discover/Connect to other moOde Players
There is also an in-place update for Beta 6/7/8/9 -> Beta 10.
It MUST be run from cmd line AND on an un-squashed /var/www !! The browser title will revert to "moOde Player" after the update. Use System config to change it, then APPLY MPD settings to get the new DoP param.
sudo /var/www/command/updater.sh r40b10
Also, BE SURE to backup /var/www and /var/local/www directories before applying the update in case you need to revert!
-Tim
I am a little confused on the upgrade process. I am currently using beta 9. Can I select "Check for Upgrade" to move to beta 10 or????
Thanks,
Gary
Hope I don't get burned to a crisp for asking, but as a totally incompetent Linux user is there ever likely to be another Moode image for Linux numpties like me? 😉
If not can anyone tell me if there are any other players out there with a specific driver for the 1794a chip?
@Alabama978
Looking on from the sidelines, here's what I see as the two likely scenarios for moOde 4.0.
1) We get an automated script, rooted in Koda59's reworking of Tim's recipe and enhanced by Tim, which, like the current recipe, starts with downloading a virgin Raspbian Stretch Lite image and ends with a bootable moOde Player. This process will take some time as various packages are downloaded, processed, and reboots occur, but unlike the current process there will be little manual input required and (I hope!) more error checking done.
2) We get a customized version of DietPi's existing configuration script which, when copied to a virgin DietPi Stretch image before first boot, accomplishes essentially the same as above, ending with a bootable DietPi/moOde Player. Since DietPi Stretch is even more cut down than Raspbian Stretch Lite, this process will likely take even longer because more packages have to be downloaded/installed and various reboots occur. Again, unlike the current process, there will be little manual input required.
Neither scenario requires as much expertise and patience on the part of the user as our current circumstance does, but neither scenario is as lickety-split quick as downloading an image and booting into moOde.
Kent
PS - burned to a crisp? Nah. 😀
Yarw!
Bingo!
Running Raspberry Pi 3 with an IQAudio Pi-DAC PRO, I have successfully catalogued and am efficiently accessing a library of over 136,000 files. I am using a 2TB Western EasyStore USB 3 drive plugged directly into the USB port on the Raspberry for its power.
I literally registered for this forum looking for confirmation of these two items. Many thanks to you, good sir.
@Alabama978
Kent
Hi Kent,
I have the front part of @koda59's wonderful work nicely adapted and streamlined 🙂 Should have the back half finished later this week. It really is a HUGE time saver and it eliminates the chance of missing a step!
I could also include pre-compiled binaries for MPD and other components which would cut the build time by half.
You might want to check out a USB SDCard drive. Its very convenient.
Amazon.com: Rocketek Aluminum USB 3.0 Portable Memory Card Reader Adapter for Micro SD Card / TF Card Reader Adapter: Computers & Accessories
-Tim
Code:
**  Moode OS Image Builder v1.0
**  Welcome to the automated process for creating the wonderful
**  custom Linux OS that runs moOde audio player.
**  You will need a Raspberry Pi running Raspbian with SSH
**  enabled, at least 2.5GB free space on the boot SDCard and
**  a spare USB or USB-SDCard drive that the new OS will be
**  written to during the build process.
**  Be sure to backup the SDCard used to boot your Pi
** Checking free disk space...
** Boot SDCard has enough free disk space
** Do you have a backup of your boot SDCard (y/n)? y
** Unplug all USB storage devices from the Pi
** Are all USB storage devices unplugged (y/n)? y
** Plug in a USB drive for the new OS
** Is the USB drive plugged in (y/n)? y
** USB drive detected on /dev/sda
** Partitions unmounted on /dev/sda
** Option: use a proxy server for Internet access (y/n)? n
** Option: install the latest Linux Kernel (y/n)? y
** Testing Internet connection...
** Internet connection test successful
** Properties and Worker files downloaded
** Adding dynamic properties
** Properties successfully loaded
** Downloading Rasbian Stretch Lite 2017-09-07-raspbian-stretch-lite.zip
2017-09-07-raspbian-stretch-lite.zip                       100%[=======================================================================================================================================>] 346.10M  1.02MB/s    in 5m 55s
** Download successful
** Unzipping 2017-09-07-raspbian-stretch-lite.zip
Archive:  2017-09-07-raspbian-stretch-lite.zip
  inflating: 2017-09-07-raspbian-stretch-lite.img
** Unzip successful
** Removing zip file
** Updating properties with .img file name
** Entering main build process
// STEP 1 - Enable SSH and remove Auto-Resize task
** Mounting Raspbian image partitions
** Partitions mounted on /home/pi/p1, /home/pi/p2
** Modifying image
** SSH enabled
** Auto-resize task removed
** Familiar network interface names enabled
** Main build script installed
** Script enabled for autorun
** Host name changed to moode
** Flushing cached disk writes...
** No extras configured
** Image unmounted
** Writing image to USB drive on /dev/sda
** This process takes several minutes...
3622248+0 records in
3622248+0 records out
1854590976 bytes (1.9 GB, 1.7 GiB) copied, 459.114 s, 4.0 MB/s
** Image write successful
** Remove the USB drive and use it to boot a Raspberry Pi.
** The build will continue automatically after boot.
Just a quick comment on using @Koda59's existing script.
First I tried the script with one of those Transcend multi-card readers. Although the correct SDCard was identified it would not write the image to it no matter what I tried.
Using one of those USB MicroSD card readers like the one Zootalaws posted above the process worked flawlessly.
Thanks for Beta 10 Tim. I did a quick update on my working version this morning. No time to play further though.
Sometimes (especially if the card has been used on another o/s) it defaults to sdd and not sdb in the linux mount table...
I have a Belkin card reader that is seen as sdd for anything plugged into it...
Took me an age of debugging to find that out...right under my nose all the time...if only I had read the mount point instead of blindly trying to write to sdb over and again ...😱
Any usb to micro-sd adapter seems to work fine for me here...;-)
@Zoo-T outlaws
I’ve got about a dozen of these, you get them with every SanDisk SD card in Asia.
You have the beginnings of a collection....;-)
How is Borneo treating you Mike ? You leave Welly and we have the longest run of clear fine hot days ever ! If it is raining there then you're the jinx and please stay until July.... 🙂
@Zoo-T outlaws
This new one that Tim teased must be able to detect the right device 😉
@Zoo-T outlaws
LOL. Yes it’s raining. We have two rainy seasons here, separated by four weeks of unbearably hot weather 🙂
You’re lucky - normally whenever I leave there’s a huge earthquake.
Does MoOde 3.8.4 resample withount setting
Good morning,
I am running MoOde 3.8.4 on a RPi3b. Sox resampling is deactivated. I feed the system by a NAS running Minimserver. Minimserver allows to resample the stream. One of my DACs is a TDA1541 (AYA DAC), which I currently connect via Audials USB2pcm bridge. The bridge has got 11.x and 12.x clocks. These should not allow the 1541 to play 384 kHz signals. Even the firmware of the brigde does not support 384kHz.
The strange thing for me is, it does play 384 kHz and I hear sound. My Hifi Cast Control App shows 384 kHz, so the stream should be sampled at this rate. As mentioned, no resampling is activated in moOde.
So I am buffled and would like to know what happens there. Does anything in ModOde does autoresample in case of a DAC does not support the given samplingfequency?
Any idea? Would be appreciated!
Best
Ernst
Hi Kent,
-Tim
Hi, Tim.
Great news about the script.
[edit] Do you mean the MPD package from the Raspbian repo? Does it implement the options you compile with? I was wondering about that while I was looking at DietPi.
USB3.0 would be great but all my "big iron" is aging in place and has only the slower USB2.0 ports. These days I work primarily from a laptop with an SD slot which shows up in Linux as /dev/mmcblk0. I have enough uSD-SD adapters to choke a horse. Read/write speeds are decent enough I haven't bothered to benchmark.
Kent
PS - I believe changes to DietPi Stretch being implemented by @FourDee will solve the WiFi problem. You'll recognize it when you see it. Turns out my hack was managing the symptom rather than the disease.
