Moode Audio Player for Raspberry Pi
Hi @bigbear2003,
If you are not able to do steps 1 - 3 to create the super-skinny image then just boot up stock Stretch Lite and start at STEP 4.
NOTE: There is a bad link reference in step 3 of the Recipe. Please re-download!
You will need this from STEP 3.
cd ~
wget http: //moodeaudio.org/downloads/beta/r40b6/rel-stretch.zip
sudo unzip ./rel-stretch.zip
Brew a pot of your favorite Coffee or Tea and have some fav tunes playing, the build takes a while 🙂
-Tim
Just downloaded v4 and this Foss + build recipe scares the hell out of me !
Pretty sure my chances of getting through that list without error are very slim indeed
Will there be an installation image in the future ? or another way of installing ?
Lx
Only if other distros that provide pre-made images integrate moOde.
If you want this to happen then post on their Twitter feeds or forums. I'll be more happy to work with them 🙂
Maybe start with DietPi and LibreELEC, two Awesome distros!
-Tim
I'm using a SD card, a Mac and are currently compiling MPD, so I don't know whether it'll all work!
However:
Do Step 1.
Write the IMG file from the zipfile via etcher.
Connect the PI over ethernet.
Boot the PI from the SD card.
Ignore Step 2.
Step 3:
1. Write the image file contained on the USB stick to an SD Card.
2. Insert the SD Card into a Raspberry Pi and POWER UP.
3. Change the current password (raspberry) to moodeaudio and the host name to moode.
login locally:
pi
raspberry
passwd
sudo sed -i "s/raspberrypi/moode/" /etc/hostname
sudo sed -i "s/raspberrypi/moode/" /etc/hosts
systemctl enable ssh
systemctl start ssh
sudo poweroff
Hi @bigbear2003,
cd ~
-Tim
Hi Tim, Is STEP 5 necessary?
Seems killed it (not able to boot) after STEP5 with something like VFS: Unable to mount root fs ....
Hi @bigbear2003,
Partitions are not being created, there are always 2 partitions, boot and root. Whats done in the Build Recipe is to set a specific size for root (3GB). Otherwise Stretch auto-resizes root to the size of the SD Card.
This is important when backing up that SD Card image. Better to back up 3GB than 128GB :-0 Read the Appendix in the Build Recipe.
-Tim
Hi Bob,
I would not be in control of what a particular distro chooses to release. I can only make the in-place updates and fixes available to them and then coordinate with the distro maintainers. This is basically how all distros work.
There are some changes that always require a new image for example moving from Jessie to Stretch which btw was a HUGE amount of work :-0
If u want moOde to be integrated into a particular distro for example DietPi, LibreELEC etc. then + post on their Twitter feed or forum. I'll be happy to work with them 🙂 This is the only avenue for pre-made moOde images going forward.
-Tim
Hi Tim,
Thank you for what you did. I use moode audio everyday!
I would like to know that if moode 4.0 can be compiled and run on a x86_64 PC?
It will make music file copying and managing easier,I assume.
If it is possible, I would like to try it.
moOde application sources are mostly plaintext PHP, JS and BASH scripts and thus are not compiled.
Have a look at the Build Recipe 🙂
-Tim
