Any Maplin MosFet Amp Guru's on here?
Aha, Thank you for working / (Explaining) that out. As I mentioned, a formula I can stare at for ages, and it makes no sense, But give the formula with an example, then I can start to make sense of them.
So looks like we're good 🙂
I forgot to add the idle power...if 50mA bias then that's about 5W. So now it's 26W and pretty close to what you have measured. 🙂
The formula for FET power is tricky because you have to integrate the Vds x Is over a quarter cycle and divide by two. It isn't as easy as the Vrms x Irms formula for the load.
Edit: Using a spreadsheet gives 21.2W. Still not far off your bench measurements and the thermal resistance is a guess. This is the price for having high power rails - poor efficiency at low power outputs.
That would explain why when I first ran them up on 15v rails, at just below clipping, they ran very cool or at least just warm.
Maybe I should put that power supply in, I don't really need 80 or even 50 watts these days 🙂
My Valve Quads, only rated at about 15w, are plenty loud enough for normal listening, and still have plenty in reserve.
For most modern speakers the power into 4 Ohms is far more important.
An amplifier that can do 50W@8 and doubles to 100W@4 is plenty for a normal room size
That require 28V peak, which allowing for Vgs and the LTP drops, is why my tweak uses 40V rails. That should still give around 70W@8 as Vgs will be lower.
The difference in volume between 70W and 100W is very small
Yes, I agree, But.... at the moment I can't really justify the expense of buying a new Toroid.
I have made hundreds of these and all worked first time without any issues, so in my opinion if you take your time making the amplifiers as per the correct spec they will work and give many hundreds of hours of listening pleasure
some pictures of my construction
Which R12 are you talking about? On my schematic it's a 47 ohm. With Vout=0V there will typically be about 5mA flowing through it and 250mV across it. Not much impact on TR5 which will have the same current but nearer 50V across it.
If this is the same R12 then I am confused if it needs to be 1W and have thermal spacers put on it.
