Studio Reference Amplifier
DC protect with triac without diac.
I'm preparing to build the SR200 amplifier.
This is a rather lengthy thread and can't find all relevant information.
As far as I understood, these are the specs:
* 200 watts / 8 ohm
* Suggested supply is +/- 65 volts (max = +/- 70 volts)
Question: what is the rated output power at 4 ohms when using a dual 65 volts supply?
Really looking forward to the build.
dual 35Vac gives ~+-50Vdc and that allows ~200W into 4ohms.
dual 40Vac gives ~+-58Vdc and that allows ~160W into 8ohms.
dual 45Vac gives ~+-64Vdc and that allows ~220W into 8ohms.
The only combination driving 4ohms that stays within the 200W limit is with the 35Vac transformer.
* 200 watts / 8 ohm
Hi Mister Apex,
Is the above assumption about power supply rail correct?
And what is the output power at 4 ohms?
Thank you!
240W into 4r0 is ~43.8Vpk.
If using a supply rail that sits at +-60Vdc when quiescent current is flowing then that leaves a margin for PSU sag and losses through the amplifier of 60-43.8V = 16.2Vdrop
In my opinion that indicates a badly built amplifier or using an amplifier for a load that is lower than the rated load.
I would expect a good power amplifier to drop between 5Vlost and 10Vlost from the quiescent supply when delivering maximum power to the rated load
I reported figures for a Leach clone many years ago running on a 40Vac transformer with supply rails sitting at +-58.5Vdc and the maximum output (unclipped) was over 300W into the resistive dummy load.
But the amplifier was not rated for that 4ohms load, at best it was rated for a 6ohms reactive load and I used it on 8ohms speakers only where it achieved >170W into 8r0.
hi friends
i built a 2.1ch system for my com A few months ago:
2*sr100 amplis
psu-10
zobel network
+33/-33 2a traffo
1.2 kva detex smps(Under Construction)
1500w class d ampli from detex(for subwoofer)
and apex vu meter
the sound quality is very good and detailed
i have a problem
when signal source is connected and audio volume is 30% and upper sound is good and not problem but when audio volume is 0% my traffo gets hot after one hour!🙁
why?
respectfully
