Ultra Simple Class D
noise
hi all i made the few modifications .now it is better and can run with 2n5401 and 2n5551 as drivers.
I make this modificatios in my amp, I use single sided board with all GND conected in your first schematic, and when i inject a 1khz sine wave, the output with a resistive load of 4 Ohms show this..
Help!!!
- I try make this amplifier, but got very noise, i change CAP C9 = 1mf x 250v in output filter and get a little reduction of noise, i use BC337 and BC327 instead 2n5551 and 2n5401 and use IRF9630 and IRF640 pair in output.
Please,,, any ideas?
hi pav you are using the wrong schematics. please change the schematics to the below components . and to avoid disappointments please use irf540n and irf9540n
below the correct schematic
I habe built this amp several time but only issue i m facing is that bd139/140 heats up very fastly and get very hot as amp is pushed to limits.
Has anyone faced such issue and if yes then what is the remedy. I m using the same design as in the first post. No changes. And i guess everyone uses the same.
Thank you in advance if anyone can help������
No one??? Really??
also here are the files for my successful class d 200w amps
i use cadsoft eagle layout for all my layout.
have fun all :cheers: 😀😀
