AZ OLED setup kits for Soekris dam1021/1121 control
If this 2 holes do not fit well into the solder, they can also be filled with heat conductive silicone rubber. The easiest way is to add a memory radiator to the 4701/3301 chip.
Thanks for your fast answer.
I'll check if there ist enough solder under the chips for best heat conduction.
I desoldered the old 3301, perhaps I'll give the old one another chance. Otherwise I'll wait for the new chips.
Greetings
Talema: 10V/25VA
Talema: 10V/15VA
Talema: 7V/7VA
Talema transformers don't seem to have dual AC10V specs. With dual AC12V transformers, be sure to solder the heat holes behind the 4701/3301 chip or add heat sink to the chip. Please note that there are altogether 4 heat conducting holes. Please warm it up first, because the copper sheath is thermally conductive. Also, don't solder it too long.
Check it out. There are 5 heat holes. Please fill in the soldering to conducte heat.
