F4 Beast Builders
I visited today again my friend Peter G. near Frankfurt.
As I told you some weeks ago, he has a good chain, Klipschorns and two Monoblocks 845 50W Master Sound from Italy and a very good pre from the same factory.
But we heard first my "Puck Beast running at home" version you can find in this thread.
Sound was a bit dark and a bit too soft.
So I asked him for two DMM, he had only one, but nevertheless we trimmed the bias of the second stage from 36mA to 42mA.
Incredible what these 6mA made a difference!
Punch, attack and dynamics, a bit too much, so we went back to 38mA .
Now the things were in the right order, attack and musicality ....
Because it was a quick adjustment the driver bias got higher after 15 minutes again and you could hear that.
So careful and lengthy adjustment fitting to the speaker you drive is a must!
So the difference between the two amps was very easy.....
The puck beast made a much greater room, was slamming details, bass an guitar passages in the room with great clarity and attack and the separation of different instruments was very good.
The room the Mastersound produced was narrower, the bass had less slam, the medium area and the highs were more coherent and the whole atmosphere was brighter and very nice too!
We both agreed that the Puck Beast is nevertheless astonishing as a DIY amp.
We all know that Nelson hears his amps a long time and fine tunes everything.
So the XA25 is for sure better.....
Nevertheless.... it is a pleasure to build a beast!
Next thing I will do, I will finish and hear this circuit, done by Peter (pr) for me.
http://www.diyaudio.com/forums/pass-labs/300233-f4-beast-builders-81.html#post4996543
Here exists no degeneration in all three stages.
Of course the regulation ist not the one Nelson uses. It is only done for the second stage with an optocoupler to avoid running away.
It behaves good in Spice and I hope same in reality.
One step further.... :--))
And I am making great progress in intentionally obscuring my circuit topology in the fashion of the XA25 photo. Everything important is on the other side of the PCB which is not shown. 😛
Generg, when you build sch. in post #983 try using 100R/10R in feedback loop instead of 2k/200R (R45/R5) and listen to difference.
10R should be 1W or so and 100 R can be made of 3 x 330R/2-3W paralleled ( it's close enough).
That is (almost) exactly what I am doing. My simulations show that the amplifier is capable of rather high class-AB power levels, so with that in mind, what is the necessary wattage of the 100R feedback resistor? I solve the high open-loop gain problem by loading the FE output at around 390R rather than using cascode feedback.
