Very nice. Net us how its sound.
Try protect without short circuit detect (remove 10k resistor)...
I remove the 10k resistor but the problem persist. What else can I do? thanks.
How to use the apex source direct switch by the way SRC/DRC Stands for? Thanks
Thank you Prasi you save me. I work two days on that pcb but nothig good. I don`t have so much talent. You pcb looks great.
Do you can make a copy of these pcb`s if you have some time free?
Thanks in advance!
Nice, again my layout ......😀
Well it sounds outstanding... Love the sound
https://youtu.be/wChAKhl-kAI
Hi dears
is this two protection correct and work ?
dear friend,
what is the use of NTC 10K? where is it fix? power amplifier's heat sink ?
dear friend,
Yes the NTC 10K need to mount on amplifier's heat skin.
question
Hi. The scheme is rabotchy? It is possible to look at PCB? There, in the first edition, paths were passed. Tell about setup of this unit... I had problems with the last cascade of strengthening...P30ZF preamplifier ...... ready for testing !
Regards,Alex
AA9 tested
looks like layout is similar to mine, is it possible to confirm?
Retro Bootstrap Amp
layout. can TIP142/147 be used possibly with reduction in supply voltage? any other resistor value needs change with lower voltage?
Nice work, no change for +/-40V rails, can you add 47nF in rails, thank you.
Hi sir Mile i have a question. What needs to be changed to get signal out about 850mv-900mv? My amp for subwoofer is need 850mv signal to get all the power of amplifier. I don't want to make a preamplifier for this, i want to use only this subwoofer filter. Thanks in advance!
Added. So power will be ~80W in 8 ohm with 40V supply?
reg
Prasi
reg
Prasi
With bootstrap you can get rail to rail peak voltage on speaker... power will be 90W/8R with +/-40V supply. Without bootstrap there will be about 75W/8R.
only if the PSU is holding @ +-40Vdc while delivering full power.
If the PSU has sagged to 40Vdc then the quiescent will be much higher, probably around 45Vdc.
Starting with a quiescent PSU @ +-40Vdc I would expect around 65W to 70W into 8r0 from a really good amplifier built to deliver lots of current.
XL2 is subwoofer filter with gain, output is 1,5V.
- 100W Ultimate Fidelity Amplifier
