100W Ultimate Fidelity Amplifier
APEX A40
Here is my APEX A40
How to use the apex source direct switch by the way SRC/DRC Stands for? Thanks
Thank you Prasi you save me. I work two days on that pcb but nothig good. I don`t have so much talent. You pcb looks great.
Do you can make a copy of these pcb`s if you have some time free?
Thanks in advance!
only if the PSU is holding @ +-40Vdc while delivering full power.
If the PSU has sagged to 40Vdc then the quiescent will be much higher, probably around 45Vdc.
Starting with a quiescent PSU @ +-40Vdc I would expect around 65W to 70W into 8r0 from a really good amplifier built to deliver lots of current.
