Arcam Delta 290P keeps blowing fuse
Why did you disconnect them? Thats not what we said to do. You want to measure the voltage drop over them with the POWER on. This will tell you the bias current with ohms law V=IR, or in this case, I = V/R.
Naturally you will get no voltage reading if they are not in circuit and no power is applied.
@Mooly, this particular Delta 290P is actually the Arcam Alpha 9 circuit. Look at the schematic for that. It has an auto-bias scheme where the voltage across R1/R1A is sensed and compared with a fixed threshold voltage by one half of a LM393 comparator. This then adjusts the bias current by adjusting the LTP tail current 😵
To be honest I cant help feeling Arcam pulled a bit of a switcheroo here. The Alpha 9 is nothing like the Delta 290 apart from the fact it uses the same output MOSFETs.
Thanks jaycee 🙂 yes it is totally different. I wonder who dreamed that circuit up 😀
You can still check the bias by measuring across R1 and R101. Anything over a couple of millivolts will be enough to prevent audible crossover distortion.
OK, I think R121 is actually the number for the capacitor to the right and R117 does not have a number or its hidden somewhere under something else. Check out 2 pics.
What setting am I checking these at.
7mV is right, and in line with what the service manual says (6-7mV giving ~60mA bias through the outputs)
0.1mV is definitely not. There is something wrong on that channel. Parts prefixed with 100 ie R101 means the right-hand channel, according to the service manual.
OK, shutting up for today, but Mooly did say "You could very carefully measure the voltage across R17 and R117 to compare. The voltage across that resistor determines at what point the output stage will conduct.
I will do that once I am sure what setting to have the multi-meter at.
Cheers guys!
When you measure voltage across a resistor, typically you should start at millivolts. If the meter shows you "over range" then you can advance up.
When you're measuring voltages across resistances like this, what you are actually doing is measuring current flowing through the resistor. As Ohms Law says, voltage (volts) = resistance (ohms) times current (amps). So if you know a voltage and a resistance, you can find current.
Interesting. That seems to move the problem away from the output stage then. Zero volts is the reason for the distortion and no bias.
The original problem of the bridge rectifier was a one off definite fault and should have caused no repercussions down the line.
We fault find this issue as we would any other but its also worth you looking back over any work you may have done, any parts replaced and so on. Check for solder splashes as well.
Make sure the -15 volts is present as shown on the diagram.
This auto bias thing complicates things. I don't know what sort of range that thing has and whether it could fully cut the bias. The voltage across C120/C107 determine the operating point. Might be worth comparing between channels the voltage across those.
Also, faults like have the potential to turn into destructive ones and so I might be inclined to go back to the bulb tester while working on it.
