DEF Amp
Antoinel
I have enjoyed reading about your DEF experiments 😀
Your contributions are both enjoyable and clear.
I have some R085s and will be waiting for Nelson to post the teaser he mentioned - transformer front end with R085s/IRFxxx
Best and thanks
Bob
Hello, Bob. Thank you for your post and kind words. I enjoyed experimenting with DEF and writing about its working. I am still learning. I look forward to the DEF teaser by Mr. Pass and articles about it.
Best regards,
Anton
The circuit of the post #121 has evolved. There's a SiC depletion mode N channel JFETs (UJN1208K). The P channel Mosfet is a IRFP9240. These are the measures:
Vds = +/- 23V
Vg1 = - 4.26V (UJN)
Vg2 = - 4.45V (IRFP)
Note spectra THD are still similars to single-ended amplifier. DEF UJN Foto.jpg
I built 10 copies, currently being played with by my listeners.
An article is forthcoming, and I'm considering a kit.
Article and kit ?
Greedy Boy are interested that fantastic news.
Thanks a bunch Mr. Pass.
Kindest regards
Vds = +/- 23V
Vg1 = - 4.26V (UJN)
Most excellent. I have played with the 1208K's also, and they are fine parts,
but a caution is in order - More typical Vgs for my samples is about 7 volts,
which will make it a difficult match for most P channel Mosfets. You may need
a decent population of parts to get the value range you want.
You have already shown in a previous post that Mosfet [pentode-like] and VFET [triode-like] cooperate nicely in a DEF amp to make a very pleasant sounding amplifier. It follows that UJN1208K [pentode-like] which has typical Vgs ~-7V can substitute for 2SK82 of ~similar Vgs. Thus, UJN1208K and 2SJ28 [Vgs ~+7V or higher] become a pseudo complementary push-pull pair in a power amp which uses or does not use overall negative feedback as in the SONY VFET diy amps.
This pair of FETs is not DEF but is an outcome of DEF's broader and unexpected utility.
