What do you think of this schematic received in a Spanish forum?
Ok, but this is what you already sent, frequency response data not the impulse file, thats why i could not open it in Arta...😀
Btw, if you export that way the phase is not exported. You need to do the following before:
* Set Minimum phsase in the View menu
* Check you select M+P (magnitude + phase) down at the left of the screen
* This will create and .frd extention file you can change to .txt to upload here.
https://www.dropbox.com/s/89lebj0zlp5sljx/SS8545%20%2B%20SEAS%20FR%20MEDIO%20SALON%20SIN%20HPF%20SOLO%20FILTRO%20CELEDONIO.Pir?dl=0
https://www.dropbox.com/s/2690jsm06apmc3s/SS8545%20%2B%20SEAS%20IMPULSE%20MEDIO%20SALON%20SIN%20HPF%20SOLO%20FILTRO%20CELEDONIO.pir?dl=0
https://www.dropbox.com/s/3gqdmf7dijj8a14/SS8545%20FR%20MEDIO%20SALON%20SIN%20HPF%20SOLO%20FILTRO%20CELEDONIO.pir?dl=0
https://www.dropbox.com/s/azr2gkd9idcltzj/SS8545%20IMPULSE%20MEDIO%20SALON%20SIN%20HPF%20SOLO%20FILTRO%20CELEDONIO.pir?dl=0
As commented before main issue is you cannot cross the SBA so low without getting a big bump under 100hz because of its impedance peak at resonnance.
Forum can't accept to attach *.frd files, I send as zip.
The Seas and the SS in phase, the SBA out of phase.
¿Mandé?🙄
Sorry if i did not make myself understood... D1 is the SBA and D2 is not the SS but the whole monitor.
I have loaded for D2 the FR of the monitor from your measurement and as you can see the tweeter is present.
If the monitor should be redesigned all 3 drivers with the full xover would be necessary.
Measurements post 151 are without the SS LPF so aren't good.
Don't understand what you measured and what for?😕
What SS LPF are you talking about? Do you mean HPF?
- Xover to filter woofer SB 23NRSX45-8
