Power Amplifier Output Inductor specification
me> a coil should be roughly "square" from the side. Length and diameter about the same. (For VERY critical work (radio tuning) there may be a better L/D slightly off from 1...
OK, I found radio theory and those guys are strange to us. They want good Q to high Q and we almost never want much Q (why we have resistors among our L and C).
Loading Inductors
As a general rule, Q in a RF inductor peaks with a form factor (L/D) between 1 and 4.
The size and shape of the conductor used in the coil sets the optimum diameter, larger conductors require larger diameters.
Lower optimum L/D ratios (near unity) appear in systems where higher amounts of external capacitance load the system. Two examples would be amplifier tank circuits or large antennas with considerable loading capacitance beyond the coil. Another way to view this is by resonant frequencies. Form factor moves closer to 1:1 when an inductor is operated far below its natural self-resonant frequency.
Higher optimum L/D ratios (up to 4:1 or more) occur when capacitance values external to the coil are reduced. Small mobile antennas without hats, especially top-loaded antennas, require longer form factors. Such systems operate the inductor closer to its self (parallel) resonant frequency.
"We" fit the "lower... L/D" case. We sock a big C in there and (without thinking) work far below the coil self-resonance. The high L/D applies when forcing skinny antennas with huge voltages (corona can be a problem for those guys), even to the point that the coil "includes" nearly all the C needed.
More thought-food: Single-Layer Air-Core Inductor Design
Yes, single-layer is a real thing in RF work. At our lower freqs, double-back winding "may" give almost 4X the L with only 2X the R (which is indeed a higher Q).
Quaker Oats containers were traditional coil-forms in crude radios. That seems large, but Dynaco wound the output inductor around a main filter cap which was maybe half the size? The aluminum would not affect the inductance. It should show eddy-current loss, but that may be "good"? If the amp did sing 1MHz, eddy current would heat the cap. I doubt the cap would blow before the slow-slow output devices of the day gave up their ghosts.
AndrewT said:
the two layer will show more effect from ..... capacitance.
Which may be the opposite of what we want?
Lazy Cat said:
Two layers inductor in FO amp acts great since it occupies small space on PCB, is mechanically sturdy (dipped in varnish) and as mentioned has very little induction effect to other parts around.
I note that you have not answered my question, apart from copying some irrelevant stuff from a Wiki. I will ask again, and be more specific this time: in what way does a double-layer coil couple less to surrounding conductors than a similar single-layer coil? I can see that a toroid would be better, but not a double-layer coil - which is essentially still a solenoid.
One of FO M builder removed output inductor, installed jumper instead and is using 2,5 nF speaker cables (see pic) without any sign of instability.
Irrelevant anecdote. What is an "FO M"?
Kay Pirinha said:
With an impedance and an (virtual) inductance, both growing with frequency? I don't think that.
Clearly you don't think that, yet that is precisely the expected result from a coil with stray capacitance. The impedance and hence 'measured inductance' increase up to the self resonance frequency. This is because the reactance of capacitance is opposite in sign to that of inductance.
PRR said:
Better concept: a coil should be roughly "square" from the side. Length and diameter about the same.
(For VERY critical work (radio tuning) there may be a better L/D slightly off from 1. We are not that fussy.)
But we want a lossy coil - low Q; we even put a resistor in parallel to ensure this! Radios generally want high Q.
To my memory it was used be called a Zobel network. There was a cap in series with a resistor to ground from the amp output and after that a coil in parallel with a resistor.
I think the idea was to load the amp at high frequencies and to avoid direct capacitive load to the output. The resistor in parallel with the coil was to dampen any oscillation.
Wheeler's formulas (from 1928!!) do a good job of predicting the inductance of a coil you just wound, based on its diameter and other geometric details: link ... and (of course!) somebody has put up a web based calculator using Wheeler's formulae
When I worked on multi gigabit serial I/O boards and ICs, our holy bible of inductance formulae was Frederick Grover's book here. We used it about as much as we used 3D electromagnetic fieldsolver software. Very handy. Beware, reading this book will expose you to the head-exploding fact that the inductance of a finite length of straight cylindrical wire, is NOT linearly proportional to length. Inductance of a wire is NOT so-and-so nanohenries per meter of length. Read the book to see why.
Quite missed my point, read again and rethink.
Why am I not surprised, ignorance is bliss.
On the other hand Accuphase guys think it's OK
Wow, looks like they use really fat wire on these multi layer coils.
I am guessing it to be 2.4mm. Coil ID about 8mm, OD about 19.5mm and coil height seems to be about 34mm. Looks like 14 to 15 turns. My calculator, estimates this coil at 1uH.
Overall dimensions approx. 34 x 18 x 18 mm
That's pretty massive. Must be for really high power. But then, whats with the Mickey Mouse relay's ?
In post 11 it was said
Lazy Cat said:
Best to use is two layer inductor, soldered perpendicular to PCB, minimizing the effect of induction currents to the other parts around.
but he seems unable or unwilling to explain this claim, or clarify if he was really saying something different. Can anyone else help him? Or should we assume that a solenoid is a solenoid, and the only things you get from double-layer are connections at the same end and more stray capacitance?
Here is the measurement setup that uses a signal generator + oscilloscope + precision capacitor, to measure an inductor.
I used a Bourns 1.0 uH, 10% inductor and an EPCOS 33nF, 5% capacitor. I connected them on my solderless breadboard, along with a 100 ohm isolation resistor. (You want Risolation to be much much greater than sqrt(L/C), so it doesn't damage the Q of the resonant circuit).
I set the signal generator to produce its largest amplitude square wave at 10 kHz. This should give slightly damped, sinusoidal ringing at the TANK_NODE and indeed, in LTSPICE simulation (2nd image), it does.
Connecting an oscilloscope between TANK_NODE and ground, I got the yellow trace shown below. In theory the frequency of oscillatory ringing should be
  • fosc = (1 / (2*pi)) * 1 / sqrt(L*C)
Rearranging terms to solve for L,
  • L = (1/C) * (1 / (4 * pi * pi * fosc * fosc))
Now we simply plug in our known values of C= 3.3E-8 Farads and fosc= 8.772E+5 Hertz. And the calculator says: L = 0.998 microhenries. Shazam! Science works! We measured a 1.0 uH inductor and our measured result was: 1.0 uH. As Nero Wolfe says to Archie Goodwin: satisfactory!
_
To everyone who sent me a PM: yes the yellow tab at bottom left of the scope image in post #38, does indeed indicate that Channel 1 (the yellow channel) has engaged the "B" feature, and that is why there's a B inside a square, on the yellow tab. "B" means "Bandwidth Limit"; I told the scope to limit the bandwidth of Channel 1 to 20 Megahertz. It is displaying a damped sinusoid slightly less than 1 MHz so BW=20MHz is not a tremendously outrageous distortion. It sure does clean up the noise; notice how clean the sinewave appears.
Good eyes!
