MOSFET Source Follower Headamp
The above amp now simulated "as-built" shows a terrific harmonic distortion profile, which explains why my buddy preferred it immediately over a Super CMOY using an OPA1688. He was so happy listening to it, I gave him the amp as a new years' present. 🙂
Schematic and HD analysis with 0.035% THD at 1.2v p-p output, mostly H2 and very little H3, and nothing else:
1k sine wave at 1.2v p-p:
FFT:
At more modest, normal listening levels of 500mV output p-p, THD is only 0.014%:
Harmonic Frequency Fourier Normalized Phase Normalized
Number [Hz] Component Component [degree] Phase [deg]
1 1.000e+03 2.634e-01 1.000e+00 -179.30° 0.00°
2 2.000e+03 3.602e-05 1.368e-04 89.85° 269.15°
3 3.000e+03 1.861e-06 7.067e-06 -179.47° -0.17°
4 4.000e+03 1.758e-08 6.674e-08 -58.31° 120.99°
5 5.000e+03 7.724e-09 2.933e-08 -0.09° 179.21°
6 6.000e+03 6.033e-09 2.291e-08 -0.15° 179.15°
7 7.000e+03 5.088e-09 1.932e-08 -0.23° 179.07°
8 8.000e+03 4.369e-09 1.659e-08 -0.26° 179.04°
9 9.000e+03 3.800e-09 1.443e-08 -0.27° 179.03°
Total Harmonic Distortion: 0.013697%(0.013636%)
I think this 4 BF862 head amp is superb bang for the buck. This amp can be made for literally under $3. 🙂
X (as Hugh has forever named you!) - coming together nicely - did you try out the switcher supply with a simple bcxxx C-Mx on this one?
I had a strange idea (with no theory or anything behind it!) so don't laugh -
What happens if/when you add some small local degeneration resistors to those output jfets just like a power amp?
Actually, Cal was the first to call me X over in the Full Range Forum. 🙂
I had degen resistors at one point but this BF862 has such a good transconductance that we try to eliminate it and match the JFETs to get the best punch for bass. I can run a quick sim with say 0.22R's and see what happens.
Here is the sim with 0.22R's added:
590085d1483649121-mosfet-source-follower-headamp-4-jfet-bf862-aksa-amp-schematic-degen.png
1 1.000e+03 6.579e-01 1.000e+00 -179.30° 0.00°
2 2.000e+03 2.272e-04 3.453e-04 89.87° 269.17°
3 3.000e+03 2.938e-05 4.466e-05 -179.48° -0.18°
4 4.000e+03 5.894e-07 8.958e-07 -87.91° 91.39°
5 5.000e+03 5.637e-08 8.568e-08 0.35° 179.65°
6 6.000e+03 1.497e-08 2.275e-08 3.86° 183.16°
7 7.000e+03 1.251e-08 1.902e-08 -0.16° 179.14°
8 8.000e+03 1.081e-08 1.643e-08 -0.20° 179.10°
9 9.000e+03 9.401e-09 1.429e-08 -0.19° 179.11°
Total Harmonic Distortion: 0.034814%(0.034790%)
590084d1483649005-mosfet-source-follower-headamp-4-jfet-bf862-aksa-amp-fft-022r-degen.png
About the same - but would mean JFETs don't need to be as carefully matched.
I'll have to build new amp as I just gave that amp to my friend. I was planning on making another batch. This time with tiny footprint to fit in Altoids mint tin for a true pocket class A amp. I know it runs on two 9v batteries well. Have to wait for my order of 50 BF862's to come in. I'm about all out of them now. Will need to match them and find two triplets again. I will leave space for the degeneration resistors though. Maybe 2.2R even?
the simulator adopts an identical model for each jFET type.
Placing identical models in parallel will result in a prediction that assumes identical behaviour.
There will be no prediction for unmatched parameters.
When you build the real thing there will be some unsimulated behaviour.
I think that's why Aksa suggested the avoidance of many paralleled output sets.
A real world test is necessary😉
