Sons of VHex
surprise surprise
Terry pulls out finished boards from sleeve. 🙄
I have done a clone in Eagle of your shematic, Valery.
Because i have only EAGLE 7.6.0 Light- full version 125€
i couldn't go more board size 80x100 mm. 3.."x4"
My idea was transform a bit to VLatFet board.
Now i am playing with given size. 🙁
I have a short try, but the library is.....hmmmm.....not easy to use- many parts missed or
difficult to find.
Marc- idefixes gives same tip.
But i will look again- tutorial shows routing is quick and simple.
Couldn't send Eagle schema zip file here.
difficult to find.
Bangla, take alook more at Diptarce as it's easy to import eagle library and schematic. I often do so. Diptrace part are not nice, i use eagle library i import so eagle parts or self made part under eagle.
Marc
Dip Trace
Hi Val and Marc.
Most parts now found in DT Library- to import is an other chapter for me, if
i am out of temporary senior moments i will try it too. 😛
I could see in guided tour- DT is arranging placement parts- that's why Val
came to quick Layout- very comfortable use.
The 0,22 Ohm as MPC-71 i couldn't find.
Two times i have tried via ,,Attachments" to send ZIP- File- it shows on pc it
works, but not in list than. Hmmm.....again - no. 😕
Hi Val and Marc.
I build some parts myself - Diptrace is very good for this.
My 0.22R 5W resistor model provides both MPC-71 and SQP cement compatibility at the same time 😉
Sons of Vhex
A step before the test.
I have them mounted on a heatsink but they are not firing up properly. Only D8 and D13 light, All other LEDs are dark. I don't have any more time to troubleshoot today so I will have to get to it later. Can you post a pic showing the components in overlay with the traces?
Thanks, Terry
Thanks, Terry
Hi Terry,
Here is an overlay, looking from the top.
Valery
