Tibi, is my controller the Bluetooth version? Also, is there an optimal grounding scheme. I still have hum when using just the controller and no gain stage behind it. I have it grounded as in your picture. Even tried ground lift circuit
Yes, it is with bluetooth. Pin is 1234. Android app is available from vicol audio : MAYA - your ultimate volume-controller
Hum can be induced by components placement, cabling, emi, oscillations etc. Can you provide some detailed pictures with your setup ?
Tibi
I also have MAYA in stock as follow:
- 2 LCD no bluetooth units at 110euro
- 2 OLED with blutooth units at 140euro
Just to clarify. Above prices are only for MAYA controller, to be used together with VoICB.
Tibi
Maya volume control for Bruno Putzey's Balanced Preamplifier
Hello,
I will be interested in the OLED controller and a volCB board if available. Thank you!
Bao
Hello,
Bao
Tibi
Tibi, I'm building a maya for a bpbp, what voltage and va transformer is required for the maya?
Min6Vac - max8Vac @ min 2A
If you power from a dc source, than 9V - 10V @ min 2A.
Tibi
Can someone tell me the dimensions of the controller/ OLED board and any other necessary boards when using the Maya with the BPBP boards?
Maya front panel design and pcb dimensions are available at vicol audio : MAYA - your ultimate volume-controller
Hope this is what you need.
Tibi
Tibi
Tibi
Thanks Tibi. Is it just module 1 you need when using with the BPBP / volcb ?
If "module 1" mean main Maya board with display and Bluetooth, the answer is YES.
Tibi
Tibi
Remote control
My phone and tablet are Apple so presumably the Bluetooth app won't work on them -?
Is the Apple remote the one for TV2 / TV3 ? Do I need to get a proper Apple one or will one of the Chinese copies be ok?
Sorry for late replay.
For the time been only Android. Apple may come if interest is high enough to cover some costs. Apple world is not free.
On infrared side, Apple make use of NEC protocol. As long your remote support NEC protocol will work.
Tibi
Tibi
So any NEC remote will work, yes ?
Yes, a NEC for audio will work. https://www.aliexpress.com/item/Remote-control-For-NEC-VEDIO-AUDIO-Remote-RM-M121/32688233766.html
This will work Apple Remote Control White : iPod Dock Macbook Pro Mac Mini iMac Apple TV 1 2 3
and this will work Apple Remote - Apple
Any infrared remote who make used of Philips RC5 protocol will work as well.
Tibi
Tibi
End of March is Friday 31. Products will be discounted for 24h starting with 09.CET
I'll come with exact prices later.
Tibi
Tibi
Tibi
I too encourage development for IOS.
Anyone could provide the additional space requirements for that Maya setup with a BPBP ?
Just have semi-finished 2 of those pre amps and looking into that specific pot replacement option to enable remote control and then some. Right now have planned (and bought already) to use a couple of rather small open frame Meanwell SMPS in a symmetrical configuration (+15.5VDC) - 0 - (-15.5VDC) for the PSU and need to calculate the case size and PCB arrangement, if this is the way to go. The PSUs are specified for max 1A output feeding a pair of +/- 12VDC Hypex regulators.
What are the additional power requirements for that Maya setup ? +5VDC (?) / max 1A enough for that Arduino board ? Anything else ?
Additional information is available on vicol audio : MAYA - your ultimate volume-controller
Maya is not arduino and power requirements are between 6V to 9V at 2A for full operation (including relay board) and around 500mA for BPBP. You may power directly Maya controller with 5V@500mA after main 7805 regulator.
For BPBP integration you need a VoICB board designed by Hans Polak.
Tibi
Tibi
- Group Buys
- Maya R2R Advanced Volume controller
