Vacuum Tube SPICE Models
EL82 or 6P18P model?
I'm hoping for a triode model for 6P18P. I'd settle for EL82, as that is supposed to be the equivalent. I haven't been able to find either one. Maybe someone has a good model they'd like to share? If not, I wonder if I can go to the well again...
EL82 data sheet:
https://frank.pocnet.net/sheets/030/e/EL82.pdf
6P18P data sheet is attached (pdf).
Thanks!
  • 6P18P.pdf
    6P18P.pdf
6P18P Triode SPICE Model
Code:
* Generic triode model: 6P18P_T_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Oct 25 09:10:51 2016
*                  Anode
*                  | Grid
*                  | | Cathode
.SUBCKT 6P18P_T_AN A G K
BGG   GG   0 V=V(G,K)+0.29755965
BM1   M1   0 V=(0.05636276*(URAMP(V(A,K))+1e-10))**-1.2853515
BM2   M2   0 V=(0.53853168*(URAMP(V(GG)+URAMP(V(A,K))/8.1874685)+1e-10))**2.7853515
BP    P    0 V=0.0041796459*(URAMP(V(GG)+URAMP(V(A,K))/15.203318)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0034271395*V(M1)*V(M2)
BIG   IG   0 V=0.0020898229*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0025089064*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 11p
CGK   G    K 6p
CAK   A    K 0.2p
.ENDS
I'm looking for a SPICE model for the 12AV7. Here is a link to a datasheet with plate curves:
www.philbrickarchive.org/12av7_ge.pdf
Thanks to anyone who can help.
LTspice?
Code:
* 12AV7_GE LTSpice model
* Modified Koren model (8 parameters) mean fit error 0.196893mA
* Traced by Wayne Clay on 9/6/2007 using Curve Captor v0.9.1
* from General Electric data sheet
.subckt 12AV7_GE  P G K
    Bp  P K  I=(0.04444253322m)*uramp(V(P,K)*ln(1.0+(-0.01749849009)+exp((2.036595788)+(2.036595788)*((55.22041769)+(-202.4359155m)*V(G,K))*V(G,K)/sqrt((54.03527608)**2+(V(P,K)-(3.013036228))**2)))/(2.036595788))**(1.271149936)
  Cgk G K 3.8p ; (3.1p + .7p)
  Cpk P K 1.0p ; (0.5p + .5p)
  Cgp G P 2.6p ; (1.9p + .7p)
  Rpk P K 1G ; to avoid floating nodes
  d3  G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends 12AV7_GE
Thanks, Wayne. Yes, I was looking for a model for LTspice.
I was also looking for models for the 7199, including both the triode and pentode sections. Somewhere along the way I came across a 7199T (triode) model you created using Curve Captor; here is that model:
Code:
* 7199T LTSpice model
* Triode section
* Koren model (5 parameters): mean fit error 0.221123mA
* Traced by Wayne Clay on 1/14/2014 using Curve Captor v0.9.1
* from Sylvania data sheet
.subckt 7199T_Syl  P G K
    Bp  P K  I=(0.01861318609m)*uramp(V(P,K)*ln(1.0+exp((0.720964335)+(0.720964335)*(62.874161)*V(G,K)/sqrt((0.712724332k)+(V(P,K))**2)))/(0.720964335))**(1.369823061)
  Cgp G P 2.2p ; 0.2p added
  Cgk G K 3.0p ; 0.7p added
  Cpk P K 0.5p ; 0.2p added
  Rpk P K 1G
  d3  G K dx1
.ends 7199T
Would you also happen to have a model for the 7199 pentode section? I have an old Koren model that doesn't give realistic results when used in the original Dynaco ST-70 circuit.
Thanks again if you can help.
Here's one I made a few years ago. I haven't tinkered with it in quite some time, so YMMV. 😉
Code:
** 7199P ************************************************************
* Created on Sat Dec 21 06:56:50 EST 2013 using tube.model.finder.PaintKIP
* model URL: [URL]http://www.mif.pg.gda.pl/homepages/frank/sheets/168/7/7199.pdf[/URL]
* Screen grid modelled using Alexander L. Gurskii's method audioXpress issue Feb 2011
.SUBCKT 7199P 1 4 2 3 ; P G2 G K
+ PARAMS: CCG=5.7p CPG1=0.56p CCP=2.5p RGI=2000
+ MU=140.384 EX=1.2599 KG1=280.0 KG2=660 KP=79.8 KVB=6.6 VCT=0 ; Vp_MAX=300.0 Ip_MAX=0.025 Vg_step=1.0
RE1 7 0 1G
RE2 8 3 1G
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LN(1+EXP((1/MU+(V(2,3)+VCT)/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG2*(2.5708-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0}
RCP 1 3 1G ; FOR CONVERGENCE
C1 2 3 {CCG} ; CATHODE-GRID 1
C2 1 2 {CPG1} ; GRID 1-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
R1 2 5 {RGI} ; FOR GRID CURRENT
D3 5 3 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
Type 30 SPICE Model
Code:
* Generic triode model: 30_AN
* Version 3.10, Generated on Wed Dec 07 06:58:37 2016
*             Anode
*             | Grid
*             | | Cathode
.SUBCKT 30_AN A G K
BGG   GG   0 V=V(G,K)+-0.99984937
BM1   M1   0 V=(0.017746886*(URAMP(V(A,K))+1e-10))**-0.27002178
BM2   M2   0 V=(0.8474472*(URAMP(V(GG)+URAMP(V(A,K))/8.5960321)+1e-10))**1.7700218
BP    P    0 V=0.00034871006*(URAMP(V(GG)+URAMP(V(A,K))/10.143443)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0002194731*V(M1)*V(M2)
BIG   IG   0 V=0.00017435503*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00022717265*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 5.7p
CGK   G    K 3.5p
CAK   A    K 2.7p
.ENDS
Type 31 SPICE Model
Code:
* Generic triode model: 31_AN
* Version 3.10, Generated on Wed Dec 07 06:58:58 2016
*             Anode
*             | Grid
*             | | Cathode
.SUBCKT 31_AN A G K
BGG   GG   0 V=V(G,K)+0.40965691
BM1   M1   0 V=(0.039301583*(URAMP(V(A,K))+1e-10))**-0.23955032
BM2   M2   0 V=(0.86229182*(URAMP(V(GG)+URAMP(V(A,K))/3.5038839)+1e-10))**1.7395503
BP    P    0 V=0.00018231552*(URAMP(V(GG)+URAMP(V(A,K))/4.0634549)+1e-10)**1.5
BIK   IK   0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00011748305*V(M1)*V(M2)
BIG   IG   0 V=9.1157759e-05*URAMP(V(G,K))**1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK  A    K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.0001624432*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK  G    K I=V(IG)
* CAPS
CGA   G    A 5.7p
CGK   G    K 3.5p
CAK   A    K 2.7p
.ENDS
