Revisiting some "old" ideas from 1970's - IPS, OPS
Parallel - continuing with "current drive" concept
My God!
Please somebody stop me! 😀
Following "Diagonal", here comes another relatively simple "current drive" design - I called it "Parallel".
Highly linear front-end, relatively low feedback loop gain (~35db), excellent stability margins, wide open loop bandwidth - hence low distortion distortion is almost constant within the audio frequency range (THD1 = 0.002%, THD20 = 0.003%).
Pretty nice harmonics profile (attached) - mostly 2 and 3 are in place.
It can be adapted to variety of rail voltages and also can be used with MOSFET output stage. Not live-tested yet.
Valery
  • Parallel-Sch.pdf
    Parallel-Sch.pdf
Yes, the full (not simplified) Diagonal front-end has got more transistors, than resistors 😀
This one - if you go for 1 pair of HexFETs - then you need only 2 drivers - you will have 4 transistors less immediately 😉
The layout can be very compact again.
Low cost heat sinks is the eternal enemy of DIYers. 🙁
If looks did not matter - a very low cost source of heatsinks are old aluminum cook pots. A 10in dia thick aluminum pot can probably serve as a good sink for a 250w class amp. Put some water in it and good for 2kW 😀
Other place to check are industrial building supplies where they make aluminum in scaffolding. Or aluminum extrusions for factory automation. They sell by the foot or meter. A 100mm square profile aluminum Bosch rail with channels for T nuts may also make a good sink.
Bosch Rexroth:
This profile is 25mm x 50mm x 1.82 meters long for about $40.
https://www.zoro.com/8020-framing-extrusion-t-slotted-10-series-1020-black-72/i/G6676871/
