Just pop in the new parameters:
.subckt 12HL7 1 2 3
+Params: MU=25.4 KP=431 KVB=1 EX=1.59 KG1=213
E1 7 0 Value = {(V(1,3)/KP)*LN((1+ EXP((KP/MU) + ((KP*(V(2,3)+.5))/(SQRT(KVB+V(1,3)*V(1,3)))))))}
RE1 7 0 1e12
G1 1 3 VALUE = {(((V(7))^EX)/KG1)*(1+SGN(V(7)))}
RCP 1 3 2.3e12
C1 2 3 2.3e-12
C2 1 2 2.1e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.model dx d(is=1e-09 rs=1 cjo=10e-12)
.ends
.subckt 12HL7 1 2 3
RE1 7 0 1e12
RCP 1 3 2.3e12
C1 2 3 2.3e-12
C2 1 2 2.1e-12
C3 1 3 0.7e-12
R1 2 5 2000
D3 5 3 dx
.ends
Oh, I think a light bulb just went on. Thanks for this.
Incidentally, do I need to change the "^" to "**" for use in LTspice? (I think I do, but I'd have to wait until this evening to experiment with it...)
Also, I assume 1 = A (anode), 2 = G (grid), 3 = K (cathode) ... correct?
I've got kevinkr's for 4P1L-triode:
I've also got this Ayumi model for tetrode:Code:* n* library format: LTSpice * Traced by Kevin Kennedy 2014-04-18 in uTgui * Unselected sample .SUBCKT 4P1L-TRI 1 2 3 ; P G C (Triode) X1 1 2 3 TRIODE MU=10.25 EX=1.48 KG1=1177.7 KP=631.61 KVB=376.5 VCT=0.00 RGI=2000 CCG=0p CPG1=0p CCP=0p ; .ENDS 4P1L-TRI
Strap g2 to the anode and it's a triode, right? It should work.Code:* * Generic pentode model: 4P1L_AN * Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved. * Version 3.10, Generated on Wed Jan 08 17:33:48 2014 * Plate * | Screen Grid * | | Control Grid * | | | Cathode * | | | | .SUBCKT 4P1L_AN A G2 G1 K BGG GG 0 V=V(G1,K)+1 BM1 M1 0 V=(0.020703576*(URAMP(V(G2,K))+1e-10))**-0.32815356 BM2 M2 0 V=(0.8205*(URAMP(V(GG)+URAMP(V(G2,K))/8.67)))**1.8281536 BP P 0 V=0.0016959897*(URAMP(V(GG)+URAMP(V(G2,K))/10.566728))**1.5 BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.00103*V(M1)*V(M2) BIG IG 0 V=0.00084799486*URAMP(V(G1,K))**1.5*(URAMP(V(G1,K))/(URAMP(V(A,K))+URAMP(V(G1,K)))*1.2+0.4) BIK2 IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-URAMP(V(A,K))/URAMP(V(G2,K))*15)-EXP(-15))) BIG2T IG2T 0 V=V(IK2)*(0.857*(1-URAMP(V(A,K))/(URAMP(V(A,K))+10))**1.5+0.143) BIK3 IK3 0 V=V(IK2)*(URAMP(V(A,K))+908)/(URAMP(V(G2,K))+908) BIK4 IK4 0 V=V(IK3)-URAMP(V(IK3)-(0.0010943584*(URAMP(V(A,K))+URAMP(URAMP(V(G2,K))-URAMP(V(A,K))))**1.5)) BIP IP 0 V=URAMP(V(IK4,IG2T)-URAMP(V(IK4,IG2T)-(0.0010943584*URAMP(V(A,K))**1.5))) BIAK A K I=V(IP)+1e-10*V(A,K) BIG2 G2 K I=URAMP(V(IK4,IP)) BIGK G1 K I=V(IG) * CAPS CGA G1 A 0.1p CGK G1 K 5.6p C12 G1 G2 3.7p CAK A K 8.5p .ENDS
I also have Ale's models, but I can never get those to work in LTspice.
Thank you kind sir!
I must have missed Kevin's post on first glance, I will see how that triode model and "strapping" the pentode model compare.
I wonder if Ale's model is for PSpice or some other sim software? I think if I rearrange his model in a particular fashion I may be able to get it to work, I have done it for other models before. BUT since I don't really plan on a build using this particular tube I doubt I will go through the trouble now that I have these. Ale's models do look very close to the actual triode curves though
yesAlso, I assume 1 = A (anode), 2 = G (grid), 3 = K (cathode) ... correct?
you have to make sure that all the "parens" are properly nested.
Incidentally, with no apologies whatsoever to Koren and the phenomenological models, but rather a compliment, my high school does a wonderful job with physics class --- they make the young folk do the experiments, tabulate the data, and then figure what properties make which equations work starting with the "frictionless puck"
Thank you kind sir!
I wonder if Ale's model is for PSpice or some other sim software? I think if I rearrange his model in a particular fashion I may be able to get it to work, I have done it for other models before. BUT since I don't really plan on a build using this particular tube I doubt I will go through the trouble now that I have these. Ale's models do look very close to the actual triode curves though![]()
It does indeed and it was made for LTSpice 🙂
Just make sure you have a 4-element DHT symbol as the model is for 4 pin triodes (2 for filament).
I updated the model with A2 grid curves:http://www.bartola.co.uk/valves/2013/09/29/4p1l-model-improved/
**** 4P1L TRIODE version 4 ** Composite DHT with Advanced Grid Current **************
* Created on 09/29/2013 08:35 using paint_kit.jar Version 2.4 Beta. May 2013
* Bartola Valves | All about electronic valves and hi-fi
* Created by Ale Moglia valves@bartola.co.uk using uTracer
* Plate Curves image file: 4P1L TRIODE 4
* Plate Data source link: Bartola Valves | All about electronic valves and hi-fi
.SUBCKT DHT_4P1L 4_A2 1 2 3 4 ; P G K1 K2
+ PARAMS: CCG=6P CGP=8P CCP=4P RFIL=13.5
+ MU=9.5 KG1=855 KP=150 KVB=745.3 VCT=0.407 EX=1.4
+ VGOFF=-3.94 IGA=0.01 IGB=0.432 IGC=11.8 IGEX=1.92
* Vp_MAX=350 Ip_MAX=140 Vg_step=5 Vg_start=10 Vg_count=9
* Rp=4000 Vg_ac=55 P_max=9 Vg_qui=-48
* X_MIN=77 Y_MIN=89 X_SIZE=492 Y_SIZE=526 FSZ_X=1157 FSZ_Y=724 XYGrid=false
RFIL_LEFT 3 31 {RFIL/4}
RFIL_RIGHT 4 41 {RFIL/4}
RFIL_MIDDLE1 31 34 {RFIL/4}
RFIL_MIDDLE2 34 41 {RFIL/4}
E11 32 0 VALUE={V(1,31)/KP*LOG(1+EXP(KP*(1/MU+V(2,31)/SQRT(KVB+V(1,31)*V(1,31)))))}
E12 42 0 VALUE={V(1,41)/KP*LOG(1+EXP(KP*(1/MU+V(2,41)/SQRT(KVB+V(1,41)*V(1,41)))))}
RE11 34 0 1G
G11 1 31 VALUE={(PWR(V(32),EX)+PWRS(V(32),EX))/(2*KG1)}
G12 1 41 VALUE={(PWR(V(42),EX)+PWRS(V(42),EX))/(2*KG1)}
RCP1 1 34 1G
C1 2 34 {CCG} ; CATHODE-GRID
C2 2 1 {CGP} ; GRID=PLATE
C3 1 34 {CCP} ; CATHODE-PLATE
RE2 2 0 1G
EGC1 81 0 VALUE={V(2,31)-VGOFF} ; POSITIVE GRID THRESHOLD
GG1 2 31 VALUE={0.5*(IGA+IGB/(IGC+V(1,31)))*(MU/KG1)*(PWR(V(81),IGEX)+PWRS(V(81),IGEX))}
EGC2 82 0 VALUE={V(2,41)-VGOFF} ; POSITIVE GRID THRESHOLD
GG2 2 41 VALUE={0.5*(IGA+IGB/(IGC+V(1,41)))*(MU/KG1)*(PWR(V(82),IGEX)+PWRS(V(82),IGEX))}
.ENDS
Hope this helps
Ale
mogliaa said:Just make sure you have a 4-element DHT symbol as the model is for 4 pin triodes (2 for filament).
Ale, can you post the 4-element DHT symbol you use with LTspice? Is it a .asy file? Thanks.
added later:
I'd like to make a .asy model for a 4-element DHT, so I can save your found parameters for various DHTs in text files in my LTspice /sub folder, and call them up within a schematic from the devices pick list. (I hope that makes sense.) Is this as simple as taking a pre-existing .asy file for a tetrode (for example) and renaming pin elements 1, 2, 3, and 4 from P, G2, G1, and K to P, G, K1, and K2?
thanks for any help with this.
Hey, I'm travelling now but when I'm back I will post it, just ping me a PM in a week if I forget 🙂
ale
ale
Many thanks, and sorry for my slowness with this stuff. If I keep trying, perhaps I can figure it out... (maybe).
I use triodedht.asy.
Version 4
SymbolType CELL
LINE Normal -48 0 -28 0
LINE Normal -20 0 -12 0
LINE Normal -4 0 4 0
LINE Normal 12 0 20 0
LINE Normal 28 0 36 0
LINE Normal 0 -48 0 -16
LINE Normal -20 -16 20 -16
LINE Normal -20 -12 20 -12
LINE Normal -20 -16 -20 -12
LINE Normal 20 -16 20 -12
LINE Normal 16 32 16 65
LINE Normal -16 33 -16 65
LINE Normal 1 24 16 32
LINE Normal -16 33 1 24
CIRCLE Normal -48 -48 48 48
WINDOW 0 8 -64 Left 0
WINDOW 3 62 -29 Left 0
SYMATTR Value TriodeDHT
SYMATTR Prefix X
SYMATTR Description This symbol is for use with a subcircuit macromodel that you supply.
PIN 0 -48 NONE 0
PINATTR PinName P
PINATTR SpiceOrder 1
PIN -48 0 NONE 0
PINATTR PinName G
PINATTR SpiceOrder 2
PIN -16 64 NONE 0
PINATTR PinName K1
PINATTR SpiceOrder 3
PIN 16 64 NONE 8
PINATTR PinName K2
PINATTR SpiceOrder 4
Looking for Spice model of 6F12P (6Ф12П) both Triode and Pentode;
found that pentode model here, but does not emulate IG2 very well, too low;
and no triode model at all;
.SUBCKT 6F12PP 1 2 3 4 ; P G1 C G2 (Pentode) 28-Feb-2008
+ PARAMS: MU= 71.45 EX= 1.350 KG1= 260.8 KP=7396.95 KC= 4000
+ KVB= 17.9 VCT= 0.00 RGI= 4500k
+ CCG=6.6P CPG1=0.02P CCP=1.9P
RE1 7 0 1G
RE2 8 4 1G
E1 7 0 VALUE={V(2,4)/KP*LOG(1+EXP((1/MU+V(3,4)/V(2,4))*KP))}
G1 1 4 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*1.57*TANH(2*V(1,4)/(KVB*3.14159))}
G2 8 4 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KC*(2.57-1.57*TANH(2*V(1,4)/(KVB*3.14159)))}
E2 8 2 VALUE={0}
RCP 1 4 1G ; FOR CONVERGENCE
C1 3 4 {CCG} ; CATHODE-GRID 1
C2 1 3 {CPG1} ; GRID 1-PLATE
C3 1 4 {CCP} ; CATHODE-PLATE
R1 3 5 {RGI} ; FOR GRID CURRENT
D3 5 4 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
it also seems that there are several typos in the data-sheet on the net:
http://frank.pocnet.net/sheets/112/6/6F12P.pdf
cathode resistors for both triode and pentode are given as 68 kohm (!) this should be 68 ohm I guess;
output capacitance of the triode is given as 0.26pF ... very low, my guess is that it is more like 2.6pF;
the pentode's voltage limit is given as 3000v, 300v it should be.
RE1 7 0 1G
RE2 8 4 1G
E2 8 2 VALUE={0}
.ENDS
Found these by Koonw: http://www.diyaudio.com/forums/tubes-valves/286561-new-d3a-equivalent-marked.html#post4609774Looking for Spice model of 6F12P (6Ф12П) both Triode and Pentode;
Code:
A) Pentode Section
**** 6F12PI_P ******************************************
* Created on 02/07/2016 22:40 using paint_kip.jar
* Model Paint Tools: Trace Tube Parameters over Plate Curves, Interactively
* Plate Curves image file: 6f12pi-p.png
* Data source link: <plate curves URL>
.SUBCKT 6F12P-P 1 2 3 4 ; P G K G2
+ PARAMS: CCG=6.6P CGP=1.4P CCP=1.9P RGI=1030
+ MU=112 KG1=101.8 KP=361.1 KVB=1.92 KVC=1.6 VCT=0.00863 EX=0.664 KG2=12
* Vp_MAX=320 Ip_MAX=37.5 Vg_step=0.5 Vg_start=0 Vg_count=8
* Rp=1600 Vg_ac=23.5 P_max=5 Vg_qui=-23.4 Vp_qui=240 UL=0.43 EG2=120
* X_MIN=102 Y_MIN=74 X_SIZE=699 Y_SIZE=646 FSZ_X=1359 FSZ_Y=856 XYGrid=true
* showLoadLine=n showIp=y isDHP=n isPP=n isAsymPP=n isUL=n showDissipLimit=y
* showIg1=n gridLevel2=n isInputSnapped=n
* XYProjections=n harmonicPlot=y harmonics=y
RE1 7 0 1G ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+(VCT+V(2,3))/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
* Alexander Gurskii screen current, see audioXpress 2/2011
RE2 8 3 1G ; Dummy
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG2*(KVC-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0} ; Dummy
RCP 1 3 1G ; FOR CONVERGENCE
C1 2 3 {CCG} ; CATHODE-GRID 1
C2 1 2 {CGP} ; GRID 1-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
R1 2 5 {RGI} ; FOR GRID CURRENT
D3 5 3 DX ; FOR GRID CURRENT
.ENDS
B) Triode section
.SUBCKT 6F12P-T 1 2 3 ; P G C (Triode)
+ PARAMS: MU=112.5 EX= 1.66 KG1= 94 KP=760
+ KVB=12100.0 VCT= 0.00 RGI=4500
+ CCG=4.6P CGP=1.6P CCP=0.26P
E1 7 0 VALUE=
+{V(1,3)/KP*LN(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID;
C2 2 1 {CGP} ; GRID-PLATE;
C3 1 3 {CCP} ; CATHODE-PLATE;
.ENDS
much better ... thanks @cogsncogs and @Koonw
had to re-order nodes as 1 4 2 3 (P G2 G1 C) though because of tetrode .asy in my LTSPICE
Version 4
SymbolType CELL
SYMATTR Prefix X
PIN 0 -48 NONE 0
PINATTR PinName P
PIN -48 0 NONE 0
PINATTR PinName G
PIN -16 64 NONE 0
PINATTR PinName K1
PIN 16 64 NONE 8
PINATTR PinName K2
Thanks for this, but I still couldn't get it to work. I've attached the error msg I got.
I tried to make a symbol (.asy) for DHT_4P1L. I'm able to do this with the Ayumi and cogsnsnogs models, but I often can't get others to work.
This is the DHT_4P1L.asy file I made. It's probably riddled with mistakes.
* NOT WORKING - DO NOT USE
Version 4
SymbolType CELL
SYMATTR Value 4P1L-T
SYMATTR Prefix X
SYMATTR SpiceModel DHT_4P1L.inc
SYMATTR Value2 DHT_4P1L
PIN 0 -48 NONE 0
PINATTR PinName P
PIN -48 0 NONE 0
PINATTR PinName G
PIN -16 64 NONE 0
PINATTR PinName K1
PIN 16 64 NONE 8
PINATTR PinName K2
Also, on this line in the sub file,
Should I move the characters "P G K1 K2" so they come right after the SYMMATR Value2 ("DHT_4P1L")?
And what is "4_A2"?
Use underscore everywhere!
DHT_4P1L_4_A2 with DHT_4P1L_4_A2.asy or delete 4_A2 subfix from name for using DHT_4P1L.asy.
I generally use triodedht.asy, and manually edit (right click) component's SpiceModel attribute to actual name (in my example to DHT_801A_A2).
6F12P uTracer measurements
Earlier in the year I was sent a few 6F12P's by Bondini to measure.
For all the tubes, I found the variation to the data sheet to be considerable, for both the triode and pentode sections. Generally emission was significantly lower.
I have attached the files and sample curve matches (pentode Vg2=150V).
Note the deviation in the triode section above 10mA. Also be aware that mu had to be set to an unrealistic high value to get a good curve fit. I have not tried this in a circuit simulation.
Hmm... My favorite tubes are being discussed finally... ;-)
12HL7, 6Ф12П, 4П1Л
I have developed models for 12HL7 as well as 6Ф12П (triode and triode-strapped pentode) in addition to the 4П1Л. I will share them when I get the chance
cheers
ALe
Update to 6F12P uTracer models
Apologies, I have now used a more recent version 3.0 of Derk Reefman's extractmodel which gives a better match and more realistic parameter values for the triode section (but measurements remain quite off the manufacturer's)
- Tubes / Valves
- Vacuum Tube SPICE Models
