Well, also an option, but you loose accuracy a bit in this case. I prefer increasing R29, simply shifting the trimming threshold. This difference in the value required may be caused by some difference in the parts characteristics. Most likely - the red LEDs used by Paulo are giving a little bit higher reference voltage.
I'm using 1.8V leds. Is there an impact on the sound by using a little higher voltage drop leds?
Paulo, that's OK. We just had to correct the resistor value in bias spreader, but as soon as we've done that - no problem.
Thanks!
Canada Post is set to possibly go on strike on Wednesday, so if anyone is interested in VHex+ boards, supplies, parts kits, or any other boards, please let me know as soon as possible. Monday could be the last chance for me to ship boards for a reasonable cost for a while.
Nice.
Please share all the SMPS files (schematic,pcb).
Sir thimios attached pcb file download in other site
The ferrite transformer used is the EI33 , can be found in side burning soures ATX computer(dcrap) andre used.
The primary consists of 40turns of 22 AWG wire(only1wire)and the secondary consists of8+8 turns of 19AWG wire(2wires together in parrallel.
I get in 35v dc
Greetings to all my vhex 1.1 in fitted diy case
Nice build! I see a digital player embedded on the right.
So, this is a media center then
Is it the schematic available?Sir thimios attached pcb file download in other site
I get in 35v dc
Can you give details about transformer?
nothing?Hi Sownel,can you give some details about transformer winding?
If you have the schematic diagram please post this here.
I vaguely remember this SMPS from another thread in this very forum, a Brazilian amp design using this PSU (hence the portugese file names)Sir thimios attached pcb file download in other site
I get in 35v dc
- IRFP240/9240 Amplifier (simulated on TINA)
