IRFP240/9240 Amplifier (simulated on TINA)
Here it is:
Well, normally the heatsink is moderately warm at idle or relatively low listening volumes.
It will become considerably hot if you run a 50W sine wave constantly during, say, 30 minutes.
Paulo, you've got the good heatsinks - even a bit bigger than our reference ones.
Well, also an option, but you loose accuracy a bit in this case. I prefer increasing R29, simply shifting the trimming threshold. This difference in the value required may be caused by some difference in the parts characteristics. Most likely - the red LEDs used by Paulo are giving a little bit higher reference voltage.
I'm using 1.8V leds. Is there an impact on the sound by using a little higher voltage drop leds?
Nice.
Please share all the SMPS files (schematic,pcb).🙂
Sir thimios attached pcb file download in other site
The ferrite transformer used is the EI33 , can be found in side burning soures ATX computer(dcrap) andre used.
The primary consists of 40turns of 22 AWG wire(only1wire)and the secondary consists of8+8 turns of 19AWG wire(2wires together in parrallel.
I get in 35v dc
I get in 35v dc
Is it the schematic available?
Can you give details about transformer?
I get in 35v dc
I vaguely remember this SMPS from another thread in this very forum, a Brazilian amp design using this PSU (hence the portugese file names)
