PeeCeeBee
I made one for my own components based on Shaans Layout.
But it is not tested!!!
regards Olaf
  • PeeCeeBee_V2_01.zip
    PeeCeeBee_V2_01.zip
:wave2:
Hi Shaan,
Thanks once again! The V2 plays super good. Very beautiful sound, worked right from the first time powered on. When I find time I will upload some measurements.
One PeeCeeBee more 🙂
regards Olaf
:wave2:
Hi Shaan,
regards Olaf
Hi Olaf,
could you post your bom... as i guess your build does not use any special parts. am i right?
To Shaan,
Could you post a bom with recommended caps (types and voltages), resistors and most importantly small signal devices and alternatives? if its already done, kindly inform the post#
reg
prasi
Hi Olaf,
To Shaan,
reg
prasi
Hi Prasi,
you're right. In my layout are no special components. Only a few small differences in layout. I hate it when the components do not fit on the pcb. Especially the diameters of the capacitors ...
So I have no BOM. And sorry, why? The PeeCeeBee is one of the most reduced to the minimum amplifier I know 🙂
regards Olaf
Olafk, 🙂
Nice work!
Can you also share your PCB layout in a pdf for photographic diy PCB making?
Thanks.
here are the files. Have fun! It is a very cool amplifier 😎.
regards Olaf
V2 BOM
To Shaan,
reg
prasi
Hi Prasi.
Here it is. I hope I didn't miss any part.
I have the small signal devices now. If you like I can ship them to you. The alternative is BC337/338 but limited to +/-35V application. However, I haven't tried this BJT so can't comment on its performance.
Hi Prasi.
Hi Shaan,
Thanks a lot. Thats a neat BOM. Let me see whats available here locally. Then will get in touch with you.
Have tried to run the V2 at different voltages? I mean like 24V, 32V, 40V etc. Did it have any effect on SQ perception?
reg
Prasi
