DTQWTII from Argentina
Go more photos !
And more, 😀, especially for Nash.
And, Crosby, Still, and Young are good ?
Follow the festival, poor little today!
"What abounds, not damage"
Hi :
I could restart the building after a forced interruption.
Here the inner corner, all in place with dowels, as always.
Greetings to the community
El Sindrome de Deficit de Atencion no me permite leer todo el historial, pero excelente trabajo, estoy ansioso por ver como quedan y tu opinión. En cuanto a unos mensaje viejos donde unos debatian como estupidos sobre el clima, la proxima vez escribe en español y esos idiotas desapareceran.
For those who don't know how to use Google Translator, or don't want to...ADD does not allow me to read the whole thread history, but excellent work, look forward to seeing the end result and hearing your impressions. Regarding old posts where some people were debating like children regarding climate change, next time continue your thread in Spanish until those rude members disappear.
Nice to see the return!
I see that the results will be outstanding!
Hello DIYBras 🙂
Espero dedicar mais tempo a essas caixas abençoadas, mas não foi por falta de desejo ou tempo, mas "força maior", por assim dizer, para não entrar em detalhes ou dar origem a qualquer off topic.
Muito obrigado!
Yo espero dedicarle mas tiempo a estas benditas cajas, pero no ha sido por falta de ganas ni tiempo, sino " motivos de fuerza mayor " , digámoslo así, para no entrar en detalles ni dar pie a ningún off topic.
Muchas gracias!
I hope to devote more time to these blessed boxes, but has not been for lack of desire or time, but "force majeure", so to speak, not to go into detail or give rise to any off topic.
Thank you very much !
Gracias amigo por tus felicitaciones, aún falta mucho trabajo, pero menos que antes ! 😉
Es cierto lo que dices, pero creo que el error fué mío al introducir un comentario fuera del tema.
Igualmente no olvidemos que el foro es en inglés, así que yo trato de ser respetuoso del mismo y escribir lo menos posible, porque realmente me cuesta mucho hacerme entender en temas que requieren un inglés fluído.
Fíjate aquí, yo creo que a alguien le habrá interesado el tema de una empresa que prueba las válvulas por software para asegurar un correcto apareamiento .....pero no hubo ningún comentario. 😀
http://www.diyaudio.com/forums/tubes-valves/144394-el34-tubes-hi-fi.html
( última página )
Tú cómo lo ves ? 😕
Thanks friend for your congratulations, there is still a lot of work, but less than before! 😉
It is true what you say, but I think the mistake was mine to enter a comment off topic.
Also not forget that the forum is in English, so I try to be respectful of it and write as little as possible, because it really easy for me to make myself understood on issues that require fluent English.
Look here, I think anyone would be interested in the topic of a company testing the valves software to ensure proper mating ..... but there was no comment. : D
( last page )
And how do you see? : Confused:
I leave pictures of angles - cornes - who have already been glued and finished in a cabinet, now I'm on the other. And then the other reinforcements that will be easier to do.
Make cuts of 45 degrees with a portable tool it is something really difficult, not recommended. Send to cut professional woodworking machines will relieve us great pain in the testicles 😀 and not have much wood waste ....
Preparation and gluing internal stiffeners 🙂 :
Pressing ..... 😉:yes:
New photos, we are moving forward, slowly but surely...🙂
Here you see how I can mark the exact place for accommodation of wooden dowels.
It is very important is that cornerbacks are in place to prepare a special wood that to use the press without damaging the veneer.
Second part, I'm almost done ...😀
Last for today. 😉
Last for today. Remember that the advantage of using billets are several:
We do not need many presses, which would rise
overall spending too.
We do not run risks move to the woods glueing.
We can adjust some court if necessary, so getting a professional adjustment of the joints.
Add some extra photos so they can see in detail stuck with glue and dowels.....😱🙂
