Good news Felipe.
Does that mean you're now getting good music and no noise?
Ray
Ray
Well fixed the noise adding LC filtering at the PSU, now CLC 2.200uF 2mH 1.000uF. Salas information: FF rather easily picks EMI
Yes, now with FF I have more gain, but I like more the SE LP filter: sounds more natural to my ears.
Couple of questions on the boards.
How are folks separating the two boards and making the correction that Ray had pointed out? Are you using a exacto knife to cut the trace and separate the boards?
Any recommendation for power supply and case? Working on putting the Element14/Mouser order together and would like to include everything in one order.
I use a Dremel with a cutting disc to separate the boards and to cut the tracks for the correction; see the pictures I posted a way back.
Felipe's experience has highlighted the need for a good power supply, certainly for the FlipFlop board. I'm getting good results with these supplies;
http://www.diyaudio.com/forums/vend...ow-noise-ldo-regulator-pcb-5.html#post4239877
Ray
Interesting. I'm planning to compare the SE and FF boards with my TVCs as I've been wondering about their relative performance.
Board received - sorry about the tardiness, I've been focused elsewhereGroup Buy Update: Attached is an updated spreadsheet showing who has told me that they have received their boards. Please let me know when you receive yours. Thanks.
Ray
Hi Ray, is there any SE board with part left?
Thanks.
Yes, I have PCBs available, I will PM you when I find the shipping cost.
Ray
Are you measuring at the FF's power terminals?
Instead of a CLC filter you could try not using the Ref-D's sense wires (connecting S to F at the reg's output) and see how it measures and sounds.
Infor for WaveIO USB-I2S owners.
I2S_BCLK = DSD_CLK only for FlipFlop users
I2S_LRCK = DSD_DAC0 =left
I2S_DATA = DSD_DAC1 =right
Attached pics WaveIO, important when using isolated I2S outputs (recommende) to power with other PSU no shared with the WaveIO power or the self powered USB.
Its time to finish. Be patient with me.
Questions:
1. LPF. Got a 15nF (WIMA MKS 4 0.015/250 F4, any recommendations) and 270R (39.297 Hz) or 300R (35.367 Hz).
2. Can I power it from USB. Use USB switch on JLSound board and power it with dirty power from USB. I plan to bay decent linear power supply but this is to test.
3. Can some one explain me purpose of board's jumpers.
PS. Sorry four my English.
Questions:
It depends of the gain structure of your system. http://www.diyaudio.com/forums/diyaudio-com-articles/186018-what-gain-structure.html
- Digital Line Level
- The Best DAC is no DAC
