HQ-IV tube output balance DAC
Hi Blitz!
Thank you for showing me,
Yes, I was confused schematic, very sorry for you!
And this is my circuit diagram!
Quanhao, I am studying the schematic and the pcb, you have two different schematic, can you please post again which one is the correct one? I am a bit confuse. The one you said was yours, it does not have C3, R11 (left), but the pcb has it?? Please clarify
Quanghau - For ECC99 tubes R5, R14, R20, R29 = 470R? Same as 6DJ8?
Is it possible to use other tubes for V2/V4 ex: 12AX7, 12BH7 if we calculate R8, R9, R23, R24 and R1, R2, R16, R17?
Or change R8, R9, R23, R24 and adjust VR's?
yes, 6DJ8 can change by Ecc99.
12AX7, 12BH7 , i not test this tube, but 12BH7 you can usre
R5, R14, R20, R29 = 470 - 1K, set curent = 10-15mA at 260V +b
and all shema for two options output. An HV supply
thanks
Quanghau - I would like to use Shinkoh resistor for R6,R12 & R21,R27 low pass filter but no 2k2. Can I use 2K4 with 470pf for filter?
Can we reduce value of 2k2 and increase 470pf for same frequency filter?
Is this correct?
Cut off Frequency: 2K2 & 470pf = 153999.67968067 Hz.
We can also use 1k3 & 800pf for same frequency cut off?
Low Pass Filter Calculator
yes, you can get the value you like!
thanks
