100W Ultimate Fidelity Amplifier
Is super A a lot better than plain Dx? As J type - I am listening to Suzanne Vega on my Dx and it is one of the few amps to handle the deep bass line properly on many of the tracks on 9 Objects of Desire album. It's a nice amp - you would be hard pressed to find a better commercial amp for under circa $1000 is my guess. That's the cool thing about DIY. If the FX8 tops this it will be very cool. I am really liking the small form factor because I want To build a 6 channel amp for my 3 way active setup. 3 amps per side bolted to same heat sink. It may be a small heat sink too if I use a small CPU cooler fan.
Just finished my PCB for APEX FX100 PSU+Protect using ultrafast MUR860 diodes, seperate relays for each channel and space for four filter capacitors (thinking of Nichicon LGU1J103MELC) Circuit is tested and works just fine.
  • FX100_Factory.pdf
    FX100_Factory.pdf
Nice work. I suggest to conect relays in series and you must decrease 1k2/5W resistor value to get 24V on relays coil.
