Tapped Horn Cabinet for 16 Hz. organ speaker
JAG,
Asking someone on this board to drive hundreds of miles to my church is silly.
I'm sorry. But in your zeal to take a swing at him, you've crossed the line IMHO into the just plain ridiculous.
BO
I take your severe public criticism of me very personally - of course - and feel I need to reply. I didn't mention ANYBODY in my suggestion.
I call to your attention that at no point in this thread of for months past on any thread have I ever replied to "him" even though - for reasons I can not understand - "he" posts a rebuttal to every single post of mine with page after page of wordy posts (that I don't read). Go figure. I have complained to the moderators (and off-list to friends at DIYaudio) repeatedly about this hostile behaviour and their suggestion is that I ignore him. Which is exactly what I do and will continue to do.
If you have a peek at my earlier call for people to help you, there was talk about folks in your region - certainly not from other countries, like Canada.
When somebody honks their horn in traffic, weirdly enough, some sad drivers all around are certain the honk must have been an implicit criticism of THEM. Is that a sign of mental disorder?
Ben
JAG,
I get your point that he's the person who keeps urging that measurements are needed for that output from the Artisan system. But you also suggested that different measurements be taken at various locations in the Sanctuary.
BO
There's 4 people that are very active in this discussion. You, Ben, me and Mark. There are a few other people posting but not many and their posts are few and far between.
When Ben posts Endless posting. and All talk and no ..., there's only a few people he can be talking about.
I reply to a lot of your posts because I believe a lot of them contain bad information, suggestions and recommendations. I usually post a ton of information in my "wordy" posts and I would love to have an actual technical discussion with you about numerous issues, although I've already posted tons of technical info on these issue in rebuttal to your posts that you apparently haven't read.
And while you don't address me directly you've taken several shots yourself with the "armchair quarterback" and "sim lover" comments.
@ Bach On
Re Post #695
I'm not Art 😀
I see asterisks, however, but no waves. Did the Admin remove these waves?
The 16Hz wave is in the Att @ the bottom of Post # 688. See my IMAGE Only of it in this post. You have to click on it to download it ! Then follow my instructions about renaming it. Also note what i said about Looping it in for eg Audacity, as it's only a short sample.
As just a guy rightly keeps saying, you REALLY do need to have a Dedicated supply to the amps etc. Directly fed from the main power input fuse etc box, with a suitable high current fuse/breaker. Ideally going to ALL the audio equipment, otherwise you could get nasty hum etc due to earth loops. This should be done with thick cable that is @ least 2 x overated in current terms compared to the max you will Ever draw. Forget about rewiring the whole church.
Originally Posted by just a guy
I would be quite interested if you could upload a 16 hz note sample from the demos, or something that contains the 16 hz note sample.
I was hoping that Bach On could do that 😉 But he, or anyone else, would have to rename the file/s before uploading to .txt as i did, plus Ensure the file size/s don't exceed the maximum allowable on here. Otherwise the forum will NOT upload it/them 😉
@ Bach On
Re Post #695
I'm not Art 😀
I was hoping that Bach On could do that 😉 But he, or anyone else, would have to rename the file/s before uploading to .txt as i did, plus Ensure the file size/s don't exceed the maximum allowable on here. Otherwise the forum will NOT upload it/them 😉[/QUOTE
Sorry Zero D. My mistake.
1. I have downloaded and installed Audacity.
2. I have downloaded your wave file.
3. Audacity loaded and ran it even without my having to rename the extension.
4. I exported it as an audio file so it would have the correct extension..
You're right. It goes by pretty fast.
My laptop speakers could do nothing with it. I'll putz around with it and see what I can do.
Once I have it, can I copy and paste in Audacity to make it longer?
Ours is an older building erected in 1928. The town had no electricity at the time. As you might expect, the electrical work was done over a period of many years by many different people. Many of them are now dead. I know where one panel box is located. I'll look for more. I don't even know if we have spaces in the panel box for additional circuit breakers.
Thanks for the good advice. I hope I can follow it.
Bach On
@ Fred, i mean Bach On 😀
I mentioned it would 😉 & about renaming the file from .txt -> .wav
I'm not surprised 😀 & careful with the volume on ANY other speaker
As i said before, you NEED to Loop it See my image of how to in Audacity 😉
JAG,
I own four NU4-6000, each is basically two of the NU-3000 in one chassis.
I was quite surprised by their continuous output capability and electrical efficiency.
The NU4-6000 performed as well on low frequencies as on mid/high frequencies, and is capable of near full power sine wave output with all four channels driven to rated output at two ohms, or two bridged mono pairs driving four ohm loads each. The $350 NU4-6000 appears to be within 3 dB of the $5500 Powersoft K10 rating on sustained (more than 1 second) output.
The NU4-6000 with two bridged mono pairs each driving four ohm loads just below the illumination of the clip/limit light each put out 85.5 volts at 60 Hz (1828 watts), 84.6 volts at 30 Hz (1789 watts), dropping the mains voltage on a 100' 10AWG 120V line from 118.1 volts down to 107.2 volts, drawing 31 amperes.
I'd expect the NU-3000 to do half the above, as much as 15.5 amperes if the organ notes have only 3 dB crest factor, but more likely the samples have closer to 6 dB crest factor, so hitting the clip/limit should draw under 8 amperes.
Using just one bridged mono pair, the amp ran for 40+ seconds before I terminated the test, as the amp was drawing 19.8 amperes, and the "tired" 20 amp mains breaker had popped several times in various tests already. The amp would have put out more power given a full 120 volts, but the test represents "real world" situation, we don't generally plug our amplifiers in to an outlet two feet from the mains transformer.
I also tested my old "heavy iron" bass favorite, a Crest CA9, bridged into a 4 ohm load it dropped the mains to 99.6 volts, drew 37.8 amps but only put out 80 volts (1600 watts). The NU4-6000 put out more power, and drew only 50% of the power from the mains compared to the CA9.
At any rate, once Bach On starts using more than the small fraction of power he tested at, he will definitely need the power amp on a separate circuit from the heaters.
Art
I found this NU 6000 bench test yesterday by accident. The results are comparable to your findings but notably different in some aspects. This is a really nice thread, well written with a lot of pics inside and outside the amp case.
Behringer inuke NU6000 vs KAM KXD7200 bench tested - Speakerplans.com Forums - Page 1
He found the amp performed significantly better at 1 khz compared to 31 hz. The logical extension of this being that it would perform even worse an octave lower at 16 hz.
He tested both a continuous signal and a 33 percent duty cycle signal and I'll just cut and paste the relevant parts of his results (with a little bolding added by me).
So, the manufacturers rated power specs are as follows:
NU6000:
The instruction manual for the Behringer actually has rms figures in it as well as their advertised inflated figures. I'm still not sure where they get their multiplier from to convert one to the other but it seems to be x1.36.....
Stereo 8 Ohms per channel: 1500W or 1100Wrms
Stereo 4 Ohms per channel: 3000W or 2200Wrms
8 Ohms:
The Behringer was happy to drive 8 Ohm loads at full power (limiter active) for 1 minute without any change in power output. With both channels driven it produced 1.17kW at 1kHz and 1.08kW at 31Hz
4 Ohms:
The Behringer was happy to drive 1 channel at 4 Ohms with no reduction in output at 1 minute. Power output was 2.27kW at 1kHz and 2.12kW at 31Hz. This demonstrates that the amp section should drive high power into 4 Ohms without any short-term limitation. However, when driving two channels simultaneously the amp would trip its protection and shut down, needing a power on/off cycle to reset. Since the power amp part was happy to deliver the power then I conclude there is a total power limit on the supply part and rather than engaging the limiters to reduce output the amp switches off. This seems a strange decision on the part of the designer, better the show go on at reduced level if the amp finds itself producing sine-wave like power outputs. It is only fair to remember however that this is a harsh test and the amplifier was pulling 24Arms from the mains at the point it cut-out! (Note: the 12A breaker on the rear did not operate as it has a time delay, this was an internal electronic limitation).
Whether this ever occurs in a music situation is debatable and the burst tests below will demonstrate its actual ability with more realistic signals. That said it does mean it is possible to trip the amp if you abuse it into 4 Ohms, not ideal.
If the output power was kept below 1.7kW per channel then the amp would not trip. To leave a margin I left the amp running at 1.5kW per channel to see if I could get a 1 minute figure. Unfortunately after 15 seconds the circuit breaker opened, not surprising at it was drawing 22A from the mains at the time. So in the end I didn't get a 1 minute figure for 4 Ohms running but I expect it will be around the 1.2kW per channel mark as that produces a current draw of 15A which would eventually trip the breaker.
To summarise, for music signals (not 100 percent duty cycle sine waves), both channels driven, you can expect an output of:
Behringer:
1.37kW into 8 Ohms, 2.05kW into 4 Ohms for full-range or mid-top duty
1.16kW into 8 Ohms, 1.80kW into 4 Ohms for Bass duty
It all starts with this.
And from there Magnets.
Lots of magnets.
Seeing as they are worth a small fortune each even at my cost.
But yes this size of driver is indeed manufacturable.
All it takes is money.
The limits of human hearing is 20HZ to 20KHZ so what advantage is there trying to produce sound outside this range?
I seem to remember reading that Whales use Infrasound to disorientate their prey. Could infrasound cause humans to swear a lot? 😱
Just found this too. LTD02 shows how to do the 16 hz hpf thing with the Inuke software but he's using a shelf filter instead of the parametric eq boost that I showed in my example.
This shelf filter can also boost the entire passband, as he shows, if your signal is low. Depending on how low the signal is and how much you can boost in the Inuke software it could conceivably eliminate the need for the DI box. So two birds with one stone (signal boost and high pass filter).
Unfortunately I don't think we can sim shelfs in Hornresp so finding the appropriate filter to protect your driver would have to be done in other software.
This method would definitely boost the signal but I'm not sure if the amp lights are connected before or after the dsp section, so not sure if the boost would be included in the signal strength lights or if the boost would be downstream of the signal lights. It would be very easy to test and find out (if you had an Inuke).
Another LTD02 Designed Sub Build - Page 5 - AVS Forum | Home Theater Discussions And Reviews
The lower limit of human hearing is not 20 hz, it's variable based on spl level. And even if you can't hear low frequencies you can feel them. You can't hear an earthquake but you can sure feel it, and it provides an immediate and substantial emotional response.
I mentioned earlier that I wouldn't discuss the point of church organs and specifically their ability to play down to 16 hz. And I won't in this discussion as the OP might not know this and might be very offended by the implications. But if you want to know more click the link, it's from BBC so it's a reputable source, and it's just the tip of the iceburg if you decide to research this on your own. A quick search on "church organ infrasound" and similar keywords will give huge amounts of information. This isn't news, this has been known for centuries and has been used to very good effect by even primitive civilizations. Another interesting and related search keyphrase is "infrasound paranormal". Lots of infrasound info if you search for it.
BBC NEWS | Science/Nature | Organ music 'instils religious feelings'
Infrasound (low-frequency sound)[edit]
Main article: Infrasound
Infrasound, sometimes referred to as low-frequency sound, is sound that is lower in frequency than 20 Hz (hertz) or cycles per second, the "normal" limit of human hearing. Hearing becomes gradually less sensitive as frequency decreases, so for humans to perceive infrasound, the sound pressure must be sufficiently high.
20 Hz is considered the normal low-frequency limit of human hearing. When pure sine waves are reproduced under ideal conditions and at very high volume, a human listener will be able to identify tones as low as 12 Hz.[38]
One study has suggested that infrasound may cause feelings of awe or fear in humans. It also was suggested that since it is not consciously perceived, it may make people feel vaguely that odd or supernatural events are taking place.[39]
Perhaps the Church knew about the above, thus the development of those huge pipes?
The lights on the NU-3000DSP are not "signal strength lights", they are output level meters.
Although some of the early MIDI instruments (the Yamaha DX7 comes to mind) had line level (+4 or more dBM) out, most now are "instrument level", about the same as a passive electric guitar/bass or Fender Rhodes piano (about -30 dBM), compatible with instrument amplifiers that have a sensitive input stage coupled to their power amp stage.
Bach On's level discrepancy is on the order of at least 24 dB (as evidenced by only getting the lowest meter light to illuminate), a direct box at most would gain 6dB, unless the DI also has a gain stage. DI boxes are typically used simply to convert high impedance (10kOhm nominal) unbalanced signal to low impedance (600 ohm) balanced line signal which can travel long distance with little loss. DI's also have a pin 1 lift (disconnect) to prevent ground loops between the audio shield and AC earth ground.
A mixer or pre-amp is required to amplify the instrument level output of the Artisian up to the line level voltage that the Crown or Behringer power amps require for full output.
You may very well be right, especially since you own an Inuke and have experience.
My info comes straight from the manual which clearly states:
SIGNAL and LIMIT LEDs display the signal level for each channel.
I have no doubt that the manual could be wrong.
As far as personal experience, all the amps I've ever owned with signal lights, it didn't matter if you hooked up an 8 ohm speaker, a 4 ohm speaker, a 2 ohm speaker, or no speaker at all, the level of the lights did not change so clearly they were addressing the input signal right after the volume knob, not the output.
Bach On only had the volume knob at 60 percent to get the -24 db light to flash, so he had a bit more gain in the tank.
This quote from the DI box wiki:
An active DI unit contains a preamplifier. Active DI units can therefore provide gain, and are inherently more complex and versatile than passive units. Active DI units require a power source, which is normally provided by batteries or a standard AC outlet connection, and may contain the option for phantom power use. Most active DI units provide switches to enhance their versatility. These may include gain or level adjustment, ground lift, power source selection, and mono or stereo mode. Ground lift switches often disconnect phantom power. Some active DI units also have electronic effects units.
I know you know that but it's unclear which Samson model Bach On purchased and how much gain it might provide.
Anyway, in all my years on the forums I've never heard of anyone adding an active DI box and still not having enough signal strength to clip the inputs. And the reason for getting the DI box is almost universally to boost the signal, at least in the forums I visit. 100 percent success, I've never seen a signal strength problem after a DI box was inserted.
We'll see shortly though when OP gets his cables and gets the DI box in the mix.
Anyway, the Inuke shelf boost (Parametric Eq - Filter 1) looks like it can boost the signal across the passband up to 15 db by itself, so I'm not sure how much extra is going to be needed with the DI box, the Inuke boost and the volume knob turned all the way up to 100 percent (instead of 60 percent). The combination of those 3 things can probably boost the signal well over 24 db.
...it's unclear which Samson model Bach On purchased and how much gain it might provide.
Possibly, and easy enough to try. I personally would want enough gain to be able to hit the amp limiters with relatively low MIDI velocity settings to allow easy adjustment between notes and different samples while at the keyboard console, and allow for the added gain of multiple notes, and allow the PEQ to be used for selective EQ rather than broadband gain.
IIRC, the log gain on the Inukes is roughly the same as on the unit posted below, -6dB at 50% (noon), 60% would be roughly -3dB. Not much but "fine tuning" above that. I had planned to label the inputs on my amps, but the pots are not very consistent, so rather than cobbling different hash marks on each amp, I run them wide open (0dB).
Increasing the level from .707v (common "home stereo" pre-amp level) to 1.4v (or so) "pro level" only requires 6 dB gain, so a "bump box" DI with 6 dB of gain would do the trick for most AV situations, but going from mic/instrument level to line level needs a lot more gain.
Fortunately, clean gain is cheap and easily available.
Art
Many good points, weltersys. I'd want a bit of wiggle room in there too.
With an extra 3 db from the volume knob, 15 db from the dsp shelf boost and 6 db from the DI box that's 24 db total, maybe just barely enough with no room for comfort.
You'd still be able to use the other parametric eq bands in this case, just not for boost. You'd only be able to use them to notch or cut.
Another preamp may be required, but that's another component in the chain, another potential for noise, component failure, low frequency roll off, etc.
I'd try to get the most out of what's already there before adding another component, although it may end up being an absolute necessity.
