You can ask for a flux band on a custom EI. Its like an anti-magnetic belt around it reducing the leakage flux a lot. Make it a 100W order since EI gets hotter than toroid as it will be passing around 40W to the PSUs in your case.What is the recommended VA rating for a 15-0-15 transformer for 1A hotrod? I keep finding conflicting answers regarding size. Some say 50VA, 80VA and others 100VA. I think some of this variation has to due with not running the transformer near it's max rated load and heat.
Also, if it matters I am considering a custom wound EI core (with distance from the PCB of course).
I am using 80watts toroid it sings quite well)
Salas,
Thanks for the feedback. I will check it further with power amps to see whether I have the issue. Most likely it will go away on its own
Andrew, yes it appears around 1/4 of the total turn
Sent from my ONE A2003 using Tapatalk
Salas,
A normal vol pot has a mechanical rotation of ~300° and an electrical rotation of ~270°the first 15-20 minutes
A quarter turn could be either 360/4 = 90°, or 270/4 = ~70°, but not 15 to 20'
Hi everyone
After using Mezmerize for two and a half - three years i decided to test my Hypnotize board.
Music does indeed sound better (a lot) but i do have one "issue". I fire the board up. I turn the volume knob at three o clock but the volume is a good bit lower than what expected. Ten to fifteen minutes later the volume does reach the normal expected volume.
Is that behaviour expected?
Luckily it was easy enough. A faulty irfp9140.
Replaced and everything works as should.
Are there fake irfps? I mean would anyone bother produce fake ones given the fact that they are quite cheap?
Low and mid improvement over the Mezmerize board sure is obvious at 200 ma. I wonder what kind of sorcery happens at 600ma.
Thanks for the help Salas.
And for the new toy of course.
Yes, it could be a messed up original but these mosfets never felt like the real deal to me. I remember when i bought them ( 2 maybe 3 years back ), they felt a tad light on the hand.. And the looks were, i dont know, compared to the ones i have on the Mezmerize (bought from mouser) these ones look like they spent a few nights out. Walks of shame may have happened too.
I think i ll replace all 4 of them, just to be sure.
No, they are to diy
Oh ok, no worries.
Who can I purchase a DIY kit from?
Wondering the cost. Is there a link to a manual and breakdown of the specs? I was just recommended this board from a friend.
Usually the beginning of a thread has a mention about the board and how to purchase etc. not the case with this thread. Sorry I can't find this info.
Thanks for all the fish!
Just wanted to thank Salas and TeaBag, specially Teabag for sending me some more transistors F.O.C. Excellent service and highly recommended if a recommendation was ever needed.
DC Offset is now -2mv on each channel, coupling this to my DC Coupled 3875's produce no problems so very happy camper here, over the coming weeks I will be testing to see if the buffer is required, the 3 pin sockets supplied make it very easy to bypass the DCB1 for comparison. I am just going to run my AV front channels through it for now which gets used for tv every day until i get time to do some serious listening, oh and to finish the build.
Salas, I did install a second set of 2.5ohm resistors, these get quite hot, i can hold them for about ten seconds before it hurts, I will have to measure the temp, I do have a quiet voice in my head saying, are they to hot to be so close to those psu caps? the heat sinks on the other hand are doing a grand job, the fets dont even feel very warm.
Is there a way to install the resistors on the all encompassing sink (insulated from it) and use extensions to the PCB?
Theres always a way, I could strip it down, drill and tap the angle bar then solder links, I dont even think the resistors need isolating but i would check, do you think the extra heat will shorten the life of the lytics because thats what i am thinking. Will having long ish cables in this position have any other detrimental effect? Maybe a lessor of 2 evils. Probably a good opportunity to fit 2 more feet because the case is sagging under the weight of the DCB1.
Measure the temperature on those nearby electrolytics first. There is a rule of thumb to derive their useful life from their ratings. Each 10C less than the max specified doubles their life expectancy. I.e. If there is a 1000 hours 85C spec it translates to 16000 hours at 45C. Resistors with ceramic back don't need isolation and simple continuity check from back to their leads will confirm.
- Analog Line Level
- Salas hotrodded blue DCB1 build
