quad, Thank you !
weskoki, yes sandblasted finish.
nbivol, Thank you !
Testing in our Ploiesti demo-room.
Tibi
nbivol, Thank you !
Tibi
is this still active Comickitkit?Dears,
The quotation from the manufacturer has came back, the quotation for 10 piece of remote control is $180HKD (around 22Euro and 24USD).
But it is not including the surface marking.
I will try one more manufacturer for comparison
It is good that now there are 10 person show interesting-:
1. comickitkit
2. syklab
3. angcl
4. tubo
5. Guarnera
6. jims
7. Fabian85
8. tomw
9. turbo
10.PHansen
To minimum order quantity, anyone still interested?
Clock mod
I have done mod with external clock: Burson clock with tentlabs crystal preregulated by Ales ''mravlca'' TPS7A4700 low noise LDO regulator.
The result is a more natural and clean sound.
And yes, those red caps are Black Gate NX 220/6.3 and big cap is a Black Gate Standart 470/16 .
Have tried there sanyo os-con SP (sound harsh and lifeless), sanyo os-con SEPC (clean sound but lifeless) , rubycon ZL (same as SEPC with overemphasis on highs),all of them suffer of missing some bass extension.
Black Gates ,after burning in period, give a juicy ,full of life sound.
Cheers
nbivol
Hi taccodude,Hello,did someone try separate Clock or other Mods on Shiga with good Results ?
Regards DT
Cheers
nbivol
Hi nbviol. did you try Tent XO before on Shiga PCB ?I got one on it and for me it is not such a big differnce to the other one. Still got some BG Caps I can try.Instead of that Evo Cap I liked that Jupiter Beeswax better(didn`t cost much more) and are pretty close to Duelund.
Regards DT
Regards DT
Hi taccodude,
İ didn't try Tent XO direct on pcb because my is 33MHz one, but have to say upgrade from citizen crystal to Burson Clock give a clear improvement, after i get on swap forum Tent crystal and swap the Burson 's and this gave me ewen more clear, fast and natural sound.
To the Burson Clock , have changed crystal's decoupling cap to mica silver and add ferride bead before crystal. Preregulation for clock is another field for improvement, tried there 78XX, lm317 and finally tps4700 .
This means that standalone clock with his own ps will give improvement over onboard crystal .
Cheers
Sent from my SM-A500H using Tapatalk
Cheers
Some videos with top loader processing.
https://www.facebook.com/VicolAudio/videos/1093843457347740/
https://www.facebook.com/VicolAudio/videos/1093847317347354/
https://www.facebook.com/VicolAudio/videos/1093848124013940/
https://www.facebook.com/VicolAudio/videos/1093848810680538/
https://www.facebook.com/VicolAudio/videos/1093849640680455/
https://www.facebook.com/VicolAudio/videos/1093850304013722/
Tibi
Tibi
Would you share the cnc drawing?
I'm willing to do so, but I need to find a way that these files are used only for DIY.
Tibi
Hi tvicol
from the board, is it J11 - J14 for is2 output?
Shiga do not have I2S output.
Tibi
- Digital Source
- Shigaclone MKII Black - The builders Thread
