BAF 2015 Coverage
The +4.7 is what's on the schematic, connected to a 10k. There was no +30 marked on the schematic that I have. Here is what I am working from:
Probably you have ready connected 4N37 optocoupler with missing connection i see on schematic ?
Was pointed by Generg 🙂
I like it very much your diy work and fell it's good time on bench.
Curious about sound :sing::note:
You need 30V. (For extra emphasis)
OK - I get the 30V. I see 28V on the schematic also.
But I am not getting 30V at either side of the 2 0R2's. Even more strange:
1. Varying the bias from +4.7 with the probe at the 0R2 results in NO change - it measures 55.5VDC.
2. Varying the rail from +60 to +30 shows 25.7VDC.
soundhappy, generg.
Please see picture of 4N37. It's upside down, and floats above the terminal block. The schematic was wrong but I connected it correctly, I think!
Thanks Sir Generg we need 4N37 wiring clarifications.
Schematic corrected now all is OK on the righ picture.
Cool :happy1:
soundhappy, generg.
It's not easy to tell the orientation of the device but Only 4 pins should be electrically connected
