This is interesting, but probably belongs in another thread.The TC9FD required more power than the compression driver, but I was amazed at the clarity at the high SPL levels I worked up to. I'm fairly used to the distortion level in speakers telling when to back off, but the TC9FD gave almost no indication of distress until the voice coil melted the glue off the former and it "gaacked" out over about a 1 second period.
I've been using the TC9FD for a few years on several Open Baffle speakers. They are on my current main system, the"Troglodyte" speakers. While I think it's a lovely driver and mate well with a 12 or 15 inch woofer, its main problem is limited SPL. It audibly runs out of steam long before the woofer does. At just moderate listening position levels in my system, the poor little things are screaming. 25ft away the distortion isn't too bad, but up close - ouch! At 2.83 volts, left and right speakers playing, I get 72 dB at the listening position. I've smoked them, too. (Be careful playing them with a 650 watt Crest amp)
Maybe it's the 1L back chamber that helps. Or maybe the horn loading is needed to keep excursion down. I just know that on OB they are nice, but don't play both loud and clean.
