Official M2 schematic
... GB is coming...
After a lot of ordering problems, I´m finally delivered next week (I´ve try about 5 manufacturers: cost gets high then the PCB consists in a lot of vias and price target should be not more then 15€).
Please be patient...
Jean-Paul
Hi!
Is it possible to use only the output stage of the M2?
Thus it would be possible to experiment with different components (transforme, autoformer, buffer stage) in the drive.
I do not know whether R1-2 are still needed....
Greets:
Tyimo
Not sure I understand your question.
The data sheet shows the relevant contacts at
1 Anode
2 Cathode
4 Emitter
5 Collector
Have you come across a different pin-out?
Nope , not a different pin-out in se but
in post #39 http://www.diyaudio.com/forums/pass-labs/281520-official-m2-schematic-4.html#post4495117
there is a pdf with , I guess , an error on the schematic .It make use of the Base ( pin 6 ) instead of the Collector ( pin 5 )
BTW no problem . I did already build a prototype and it works like a charm .
Nice sound .... and next days probably the other channel .
I did notice the PSRR being lower than the F5 . Should I look at a regulator or C-R-C-R-C until I am satisfy ?
Would there be an advantage to replacing R3 and R4 with a 200 ohm P2 as in the most recent versions of the F5 to adjust offest to minimal distortion?
Can anyone point me to the referenced F5 design and enlighten me why it would be 200 Ohms and not 20?
Is there a pedestrian procedure how to adjust to minimal distortion apart from my stellar hearing? Or is it simply adjusting to have DC vanish?
